Technics of measuring erors - Office Equipment & Supplies
Canon 2870 eror 0024
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
Jan 10, 2018 | Canon Office Equipment & Supplies
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
Erore code 2000010 How to Adjust??
bagaimana cara mengatasi print epson eror 20000010
Jan 12, 2014 | Epson TM-T60 Printer
Turntable drive belt slips off?
If you measured the worn belt, it might have stretched by 5-8% from the original length. Thus the new belt could be too large. I can't find a reference to the original Technics SG2500L belt. However one site, http://www.turntablebelts.com/panatech.htm , suggests that the appropriate belt may be the FBM 23.6" (60 cm). This is the generic belt for a range of Technics turntables. If they list a turntable model, then they know a different belt is needed.
The best way to measure the belt length is to wrap a string or wire around the belt path on the turntable. Follow that path exactly. Mark the point where you overlap the string or wire. (In case you keep your fingers on the end of the string, mark both the start and end points by drawing your line across both sections of the overlapping string.) Remove the string or wire and lay it flat. Measure the length from one mark to the other. That's your true belt length.
I hope this helps.
Jan 05, 2018 | Audio Players & Recorders
Ei eror message
If you have a wrist monitor the E1 error code indicates an "Air circuit abnormality". Solution: Measure again. If this continues to occur, contact HoMedics Customer Support 1-800-466-3342.
Hope this helped you and thanks for choosing FixYa.
Sep 04, 2011 | Walgreens By Homedics Automatic Blood...
Eror 1203 at dell printer? what is this?
I found if you cover a copper contact on the color cartridge the erroe clears and the cartridge works. looking from the contact side for the color cartridhe 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape.
Jul 27, 2010 | Dell Office Equipment & Supplies
Eror 05 is shown and flash will not pop up
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Canon EOS 450D Digital Camera
27 people viewed this question
k24674
jasbo
jasbo
