Question about Honeywell Heating & Cooling
What do I do when my honeywell thermostat says it needs serving.we replaced filters and drained tank and the message is still on screen
  • Honeywell Master
  • 1,869 Answers
Those alerts are usually setup in the settings menu on the tstat. They are on a timer and have absolutely no idea what's going on with the machine (i.e. 30 days, 60 days, 90 days etc.) Gotta get a manual and go through settings and change to off or no reminders. Good Luck!!
Posted on Apr 24, 2017
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: how do i stop the filter message blinking?
go to www.honeywell.com, there they have a search engine. Put in your model number of the thermostat and look for the users manual.
Posted on Dec 28, 2007
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
SOURCE: I have a Honeywell RCT8100A
Hello SUE check the blower door is put back tight (if you removed it to replace the filter) there is a door switch that has to make.If not we need more details on the problem.
Posted on Sep 02, 2010
pendletonhea
  • 144 Answers
SOURCE: I have an old (14 years) honeywell thermostat,
I subjest the honeywell pro 3000 is a very good stat it comes in programable and non programable their is also a pro 8000 that is great its touch screen and has many options but the 3000 is most cost effective
Posted on Sep 14, 2010
How do you unlock it?
How to Over-ride the settings on your Honeywell Thermostat ...
? 0:58
https://www.youtube.com/watch?v=ofenS8mOJDs
Oct 18, 2010 - Uploaded by Sherlock Homes Austin
If you've just bought a new David Weekley Home at Mueller, youmay ... How do I "factory reset" the th8320zw honeywell thermostat? ... Would that be the same for Trane thermostats? ...is there a way to unlock the screen?.
Venstar. T-1700 Thermostat. Which Buttons Do What ...
? 4:21
https://www.youtube.com/watch?v=PbfyzplRYco
Mar 9, 2013 - Uploaded by OcRefrigeration & H.v.a.c.
I will do a Video on Programming the T1700 at a Later Date. Soon. Similar thermostats include---Pv100 and the Pv110. Serving--- All of Orange ...
Oct 18, 2015 | Universal NIB LUXPRO PSP511L Digital...
Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
Jun 19, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
RUUD PVP75E-1 Gas Water Heater short cycling
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
Feb 01, 2013 | Water Heaters
I have an old (14 years) honeywell thermostat, that showed 1bat lo message on the screen. I replaced the batteries, but it still shows the same message and I cannot adjust the temp. I recall earlier...
Sep 14, 2010 | Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat blank screen where would fuse be?
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Jun 01, 2009 | Honeywell Programmable Thermostat Heater
Check in the heating unit itself for an automotive style fuse.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
How do i stop the filter message blinking?
Dec 27, 2007 | Honeywell Programmable Thermostat Heater
EEE error message
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Oct 29, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
