Question about Goodman CLQ36AR49 Air Conditioner
My A/C is turned OFF, but the Air handler is running. How can I fix this???
    Scholar:
  • 117 Answers
You need to check your thermostat setting to see if the fan setting is in the always on setting instead of auto setting as this would cause the air handler to constantly run. Hope this helps.
Posted on Jul 25, 2009
I want to fix my split system ac.
You are referring to the air handler portion of AC. One of the fan blades is hitting something. Kill the power to all of ac and air handler and open up the air handler by removing the panel facing you exposing the fan. Manually turn the blade and look for the offender. Bend back into place, put back panel and tape up properly and turn all breakers back on.
Ir maybe just moving the fan motor itself slightly will do the trick. Whatever is easier and works will do.
Sep 08, 2015 | Heating & Cooling
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
Th5320u101 thermostat is flashing cool on and the
1) If the OUTDOOR A/C Condensing Unit is running BUT the indoor AIR HANDLER is NOT running, the problem could be as easy as changing the RUN CAPACITOR which is usually located within very close proximity of your indoor air handler motor. Ensure the ELECTRICAL DISCONNECT SWITCH is "OFF" and change the oval run capacitor (usually a 5 microfarad capacitor). This SHOULD fix your problem.
2) If the OUTDOOR A/C Condensing Unit is NOT running BUT the indoor AIR HANDLER is running, the problem could be as easy as the outdoor unit is not receiving the required 220 Volts AC. Turn the circuit breaker for the A/C Unit OFF and then turn it back ON. Ensure the circuit breaker SNAPS when you turn it to the ON position.
3) If the previous two steps to not apply or do not work, go to the paperwork supplied with the Thermostat. Almost every manufacturer provided a TROUBLESHOOTING GUIDE within their literature. Follow those steps. If their TROUBLESHOOTING GUIDE does NOT fix your problem, they should have a TOLL-FREE TELEPHONE NUMBER provided to contact their TECHNICAL EXPERTS with your problem(s). Call them and ask them what could be causing the problem.
Aug 31, 2014 | Heating & Cooling
Air conditioner fan is blowing but not air coming
If you mean that your OUTDOOR AIR CONDITIONER FAN MOTOR is blowing AND no air is coming out of the vents within your house, it clearly indicates to me that 1 of 2 things are wrong.
Either (1) your INDOOR AIR HANDLER is NOT running or (2) the INDOOR AIR HANDLER is running but your PLENUM has come apart.
If your INDOOR AIR HANDLER UNIT is NOT running, it could simply be the circuit breaker is OFF/TRIPPED and simply needs to be turned OFF; then turned ON. If that does not FIX your problem, then it is most likely your 5 micro-farad run capacitor for your indoor fan motor needs to be replaced. It will prevent your indoor fan motor from energizing. Worst case scenario would be your INDOOR FAN MOTOR has windings burnt and needs to be replaced. If your indoor air handling unit is equipped with a CONDENSATE VALVE CUT-OFF SWITCH, check to see if your drain pan is filled, thus energizing the switch. If the CONDENSATE VALVE CUT-OFF SWITCH is ENERGIZED, it will prevent the AIR HANDLER FROM energizing. That is the design and the reason for this valve.
Good luck.
Aug 26, 2014 | Heating & Cooling
I installed 18 seer heat pump&air handler with communicating stat,i turned power on to air handler,not heat pump,stat learned air handler&heaters properly.turned power on to heat pump,stat does not...
Dont know what equipment you have but yes of course there is a fix. Turn power off to air handler. cycle power to heat pump and be sure the board is configured properly to match your outdoor unit. Then turn power on to indoor unit and likely go through system setup once again. provide model numbers of all communicating components if more problems.
Dec 10, 2017 | Goodman Heating & Cooling
What does aux mean on a honeywell Thermostat? the heat doesn't seem to be working but warm air is comming from the vents and the heat pump fan is spinning just not enough to match the temp. it's set too....
The aux switch is for electric heat banks installed in the air handler. Depending on the outside temp. it may not be efficient to run in heat pump mode but in aux. or emergency would run the electric heat in the air handler.
Dec 11, 2009 | Goodman Heating & Cooling
Air handler will not run clogged up drain?
the air handler is in the attic or in a closet right? most likely the drain switch mentioned is in a pan located underneath the air handler, the switch is actuated when the condensation drain tube is clogged, ( when it cannot drain the water out of the pan), the float switch is actuated and the unit shuts off to prevent any more condensation, thus preventing overflow into your house/apt. the drain line can be sucked out by using a simple wet/dry vacuum of any kind from the end of the drain line ( usually a 3/4 inch PVC pipe located somewhere outside ).
Aug 14, 2008 | Heating & Cooling
Lennox CB26UH Air Handler stopped running
Do you mean the air handler fan doesn't run but the outside part runs? If that is the problem, try turning the fan blade with a stick. If it turns freely, you have an electrical problem. It could be a relay, a bad motor winding, a bad capacitor, or a bad thermostat, among other things. If the fan won't turn, the motor needs to be replaced.
Jul 23, 2008 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
128 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
