Why does my plasma TV not stay on until it's warm?
When I initially turn it on I have to press the power button about 30 times before the tv finally stays on.
    Top Expert:
  • Televison & ... Master
  • 41,839 Answers
Could be a failing power supply.
Posted on Apr 24, 2017
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pioneer plasma elite pro-504pu how do reset to factory mode on standby mode >??
hi,
u cam reset ur only by the following way.
p { margin-bottom: 0.21cm; }
In order to enter Service Mode, TV guide must be turned off
In order to do this procedure you must have and use the correct remote. The full function remote that
came with the set has a TV Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not yet been setup, then the 1st step is to follow instructions to set TV guide up.
Enter ZIP code, cable or ant. Etc.
1.press and release the "TV Guide". TV guide will appear on the screen.
2.Navigate to the TV Guide tool bar and use the ">" button to select "setup" in the menu and press
and release the "enter" button
3.use the "arrow down" button to select "default options"
4.press and release the "enter" button and select "general defaults"
5.press and release the "enter" button (opens menu on lower left side)
6. use the "arrow down" button to select "auto guide"
7. use the ">" button to select "off"
8. use the "arrow down" button to select "done"
9. press and release the "enter"
10. press and release the "TV Guide" button to turn the display off
System Reset Using Service Mode:
1. Enter Service Mode
2. Use the "muting" button to select "initialize" screen
3. While on the "initialize" screen
4. Use the "down arrow" button to select "final setup"
5. Press and release the "enter" button to select "data reset"
6. Use the ">" button on the remote to select "yes"
7. Press and hold the "enter" button until the screen goes black release "enter" button on remote.
8. Power the unit off using the remote control
9. Unplug the power cord from the media receiver to complete the reset
10. Plug in the media receiver; turn the system on and reset is complete.
ok
Jan 11, 2011 | Pioneer Televison & Video
My vp322 visio will not power on
Power supply in your TV went from bad to dead. You can remove rear cover and try to locate bad capacitors (they will have bulged tops instead of flat ones). Replace them and see if it's going to resurrect TV. If not - whole Power Supply board have to be replaced.
Regards.
Russ.
Apr 04, 2010 | Vizio VP322 32 in. Plasma TV
Brookstone jumbo remote control - 2006, I've lost the manual on how to program it to my parents RCA tv. It does not have a code search button on the remote itself.
finally found answer online... power off the TV press the tv/dvd/aux/etc button until the red power light turns on and stays on, then press the power button on the remote one time, then once it's on use the channel up/down button pressed repeatedly until the TV turns on, then select input to store the code.
Feb 16, 2010 | Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
