Manual what type of of speakers to use add subwolfer, middle speaker no sound, would like manual
lynchms
  • 93 Answers
SOURCE: add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Posted on Feb 04, 2009
DickCanFixIt
  • 948 Answers
SOURCE: 5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Posted on Feb 22, 2009
sodeep
  • 3267 Answers
SOURCE: speakers
Visit this kink: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q and download the latest driver for free....sodeep
Posted on Mar 22, 2009
SOURCE: 5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Posted on Oct 02, 2009
  • 1584 Answers
SOURCE: IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Posted on Dec 22, 2009
The subwolfer only plugs in one slot, How do i get the reg speakers plug in and wrk??
I be willing to bet they plug in to the back of the subwoofer. let me know if this works fpr you Cheers!
Sep 01, 2010 | Logitech LS-21 2.1 Speakers
No surround sound
Check the wiring while it is ON, there might be a loose wiring... also check the power of the amplifier... then check the TV setting for the activation of the surround system...
Post me the results... hope this Fixya the problem...
Feb 17, 2008 | Harman Kardon AVR 630 Receiver
There is no sound in the subwolfer but the right and left speaker have sound
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' theAudio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback Next, click on the 'Active"Speakers.” Click “Configure” to "Audio channels". The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. Hope this helps’ Ya
Jan 29, 2010 | Altec Lansing ACS 295 Computer Speakers
Subwolfer does not play with cd's, plays fine with dvd's
Some amplifer's have controls to switch subwoofers off in some modes. Have you accidently switched it off?
Dec 13, 2009 | Yamaha Digital Sound Projector Home...
I added 2 more speakers and a subwolfer to my gateway pc,no sound
thats because there are no extra ic amp chips to run the speakers you can only put extra speakers on if the unit if it is designed to have them added
Oct 26, 2009 | Gateway DX4300-03 Desktop PC
How do I hook up my 2 speakers and subwolfer to my computer.
I have found the link for your instructions www2.yamaha.co.jp/manual/pdf/av/english/pcS/YST-MSW10.pdf
Aug 12, 2008 | Yamaha YST-MSW10 Computer Speakers
I-trigue 3000
my crative I_trigue 3000 speakers keep going off during music like its not getting enough electricity but is pluged into a seperate plug directly to wall.
May 06, 2008 | Audio Players & Recorders
JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Sep 30, 2007 | JVC RX-6018V Receiver
26 people viewed this question
 Grubhead
Grubhead
