Question about SCOSCHE Car Audio & Video
Brand new system not working
Had my scosche scdbta60a hooked up by a professional and it's not working.all the wiring is right, power tested on all wires. Reset not funtioning when the faceplate is on. Only sign of life is a red light when I do a reset with the faceplate off.
    New Friend:
    Problem Solver:
  • 5 Answers
Check your fuses.
Could be just a defective product...
but really check those fuses
Posted on Apr 25, 2017
Scosche SCDBTA60A when hooked up to the wiring in my truck will not power on the head come on when first plugged in and then shuts off
Believe me that is only the start of your problems, the unit is one of the most disappointing things I have ever bought, it doesn't work using a memory stick either using the buttons or the app it needs a complete rewrite of both firmware and software and Scosche tell me they are not rewriting either so tough luck!! Check other forums for other opinions but whatever you do don't buy it.
Mar 17, 2014 | Scosche Industries Car Audio & Video
Hey i have a scosche in-line fuse block i purchased. I haven't had any problems until recently. My fuse fried. So i bought more and went to replace it and every fuse i try instantly fries. i cant seem
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
Jan 30, 2014 | Scosche Industries Car Audio & Video
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Oct 31, 2010 | Car Audio & Video
How to install Scosche - 2-Channel Adjustable Line-Out Converter
If it is an active converter and not passive, you should have three power wires, black goes to ground, yellow to battery, and red to the remote/amp (blue) wire off the deck. Then there should be four input wires. These connect to your speakers, white-white/black to left, grey-grey/black to right. Black line indicates ground, or (-). Then simply hook up the RCA jacks to your amp! Caution: the Scosche only accepts 80w of power, 40 per channel. Otherwise you rick blowing the converter, possibly the amp (usually a mosfet), and then possibly the subs, though not likely.
Mar 05, 2010 | 1999 Ford Explorer
HID will not funtion hooked up right. They won't light. Everthing works as it should hit hi beams fog lights go out hi beam light comes on inside on dash. Its easy hookup maybe missing something? This is a...
yeah, shouldn't be that difficult. red-power, black-ground. unplug them then put everything back to normal, then try them to see if the originals(low beams, high beams, fog lights) work ok. if they do it's in the wiring. turn on your low beams and that's the wires that you need. just find the one that sends 12volts to the low beams and hook it up to red on HID's then hook the black(ground) from HID to chasis, not the ground wire from car and check to see if they work.
Sep 24, 2009 | 2009 Honda Ridgeline
Schoche converter trouble
yes , if you do not make your connections right you could probably damage the high to low, verify that all the wires you tapped into where speaker wires
Jul 15, 2009 | Scosche Industries Scosche Slc4 Speaker...
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
Car Audio & Video Logo
Top SCOSCHE Car Audio & Video Experts
ray gallant
Your Consultant
Are you a SCOSCHE Car Audio and Video Expert? Answer questions, earn points and help others
