Question about Vacuums
My DustBuster is making a jet engine sound - scary loud
  • 998 Answers
SOURCE: Loud "jet engine taking off" type sound
If you changed out the power supply then the only other device that could be making that noise is your CPU cooling fan. To be sure, open the case and disconnect the CPU cooling fan plug from the motherbrd (MAKE SURE POWER IS OFF) and see if the noise stops. Don’t worry about the “Fan Failure Error” when you turn on the computer. Just hit F1 to continue. Don’t leave the computer running without the fan plugged in longer then necessary. After tying this procedure, please contact me for further diagnosis.
Posted on Oct 18, 2008
SolutionGuy
  • 331 Answers
SOURCE: Loud whirring sound
Hi Arts,
You are correct only if (and I assume) it's making a heck of alot more noise than normal during spin. This definitely indicates a failed drive assembly. As you can see from the drawing below, it's a real bear of a job to repair this. Fortunately, if it's less than 5 years old it's a warranty repair! If it's less than 5, click this link for Frigidaire contact info.
If it's over 5? Well Arts? All I can say is that if you are very confident in yourself, good with tools and are very patient then you could do this repair. Otherwise, I'd call an appliance repair shop and ask for a quote/estimate to remove and replace the drive system (it'll be more than you want to spend, I promise you).
I know that this isn't what you wanted to hear, but it is what it is. I put this picture together for you so you could see what I mean...
SG
Posted on Mar 24, 2009
tbirdfan1
  • 3051 Answers
SOURCE: It makes a loud whining noise when it is on the
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Posted on Dec 25, 2009
  • 457 Answers
SOURCE: dishwasher runs for about one half hour and then
you probably have something stuck in your drain propeller or circulation pump. let me know if this helps.post a 4 thumbs post
Posted on Feb 28, 2010
SOURCE: making a loud jet engine sound
We had this problem also, the easy fix for us was taking out the soil container, then reach in and grab the gray cylinder and twist left to unlock it. pull it out, sometimes pet hair clogs the ports that make the cyclone action. Once you clean it out, put it back in and twist to lock position. There is a little lock/unlock indicator on that gray cylinder. Hope this helps, it fixed our "jet engine."
Posted on May 09, 2010
When using the vacumn today it now sounds like a jet engine and is sooo loud. What has happened to cause this ? Thank you.
Are all the air filters still in place?
Have you made sure it is not clogged at the suction point up inside at the floor?
Apr 14, 2015 | Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Making a loud jet engine sound
Apr 13, 2010 | Bissell Upright Vacuum - The Pet Hair...
User manual needed.
Black and Decker website offers product manuals. Also, various online vendors provided information I needed about DustBuster in product description, making it unecessary to purchase manual.
Sep 10, 2009 | Black & Decker V9660 DustBuster Handheld...
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
Cyclonic 14.4 volt DustBuster started loud humming noise?!HELP
Ours began making a hideous grinding racket and then quit altogether. Upon disassembly, I found a plastic guard protecting the fan that had warped and was preventing the motor from turning at all. Your problem may be related to the same plastic guard. I removed mine and now all is well...I think. If only I could find a replacement for this little guard. Every online parts distributor I've seen will only go as far as selling filters and prefilters.
Nov 20, 2008 | Black & Decker AV1200 DustBuster Handheld...
The dustbuster part of my electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=543675
Generic problem for all Vacuums
Posted by nrosener on Apr 25, 2008
The dustbuster part of my Electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem, I would suggest that you take it to an Electrolux dealer or try you local vacuum cleaner dealer in your area, all it may need is a slight adjustment to the back of the dustbuster or the part that releases the Electrolux dustbuster, it may be to tight and would need and adjustment or replacement in order for the item to release properly. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
How do I empty this dust buster?
Most of this type have a bag filter that you take out, it is just insie the front part that you take off , then you can empty and clean it.
Dec 23, 2007 | Black & Decker CK1300 Dustbuster Wet/Dry...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
