SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
SOURCE: Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
