Have horizontal lines when first turn on they go away after 5 or 10 minutes
  • 668 Answers
SOURCE: line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Posted on Nov 25, 2009
  • 139 Answers
SOURCE: 42 inch toshiba has horizontal white lines when
This issue is usually caused by some "lazy old" capacitors in the Vertical sweep section or cold solder joints. That is a large TV so it would be worth having an experienced 'old school' tv tech fix it. They can easily find the bad component using Freeze Spray that will reproduce the problem by acting as a cold start. Either way this issue will not damage anything else on your tv and may or may not get worse over time.
Posted on Jan 07, 2010
  • 53 Answers
SOURCE: Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Posted on Feb 01, 2010
  • 269 Answers
SOURCE: screenplay 5700one horizontal line across entire screen, comes on
this could be the main board or the dmd board on the light engine. you can try disconnecting, cleaning the connections with an approved board cleaner, blow the connections completely dry and then reseat the connections firmly. This has worked many times for me. If the problem still persists you will have to have the projector tested to find out what needs to be replaced.
Posted on Jun 16, 2010
SOURCE: Have VS 70705 Projetion TV 9yrs.new horizontal lines
has squiggly line on top
Posted on Oct 09, 2010
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Fix horizontal lines
Just buy a new computer monitor. It is not worth the cost to repair it.
Jun 29, 2013 | Sceptre Computers & Internet
Picture started fast horizontal paging
Horizontal synchronization circuit should be troubleshooted.
Sep 04, 2012 | Zenith Televison & Video
Feb 01, 2010 | ASUS Eee 1000H Notebook
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Horizontal lines when I first turn on my Pansonic 51" PT-51HW41 Projection TV
It's probably failing capacitors, does it squeal while this is happening?
Jan 14, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
