Question about Home Fencing
G8Z GATE MOTOR MANUAL - Home Fencing
    Top Expert:
  • 41,955 Answers
Try Googling (brand)(G8Z)(manual) without parens.
Posted on Apr 24, 2017
The manual override on my ET 500 does not work. Problem is I have no idea on what principle it works so I cannot even think about fixing it
Disengage motor from gate by using key to unlock latch and pull release latch back to disengage motor gear . Then side gate back
Oct 04, 2017 | Cars & Trucks
Lift gate will not power down to closed when button on gate or remote is pushed. Lights do flash though.
There are switches on both ends of the course of the motor, if one fails it will only work on the side that´s ok. That´s why it opens but do not close.Check it out.
Oct 24, 2015 | Cars & Trucks
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Super 500 g8z gate motor Manual
How do u connect a new remote control to the super 500 g8z gate motor?
Oct 23, 2013 | Home Fencing
You can hear my gate motor working, but the gate does not open or close. you can open and close the gate by hand. it is as if the gear does not engage
Your manual override is active. This disengages the gearbox from running the gate. You will need to release the manual override. What make and model gate motor is it?
Apr 03, 2012 | Cars & Trucks
Elite slider gate opener sporatically stops partially closed
first guess a bad electric motor
second guess to much resistance between the gate and the tracks try manually moving the gate does it get stuck at some point
3rd tighten any and all loose bolts throughout the system
Feb 04, 2018 | Home Security
My gate starts to open but then stops
Need more information.
Firstly, engage the manual release inside your motor and then operate gate by hand. Pay attention to any spots that are hard to push, this would indicate some sort of mechanical obstruction causing the motor to stop. Try remove obstruction.
Secondly, measure the voltage on your battery while trying to operate the gate. If your battery drops below 11.5V the control board will shut down. If so, replace battery.
Feb 04, 2012 | Apollo 7000etl Slide Gate Opener Plus 2...
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
Rear power door not working
check the gate suports.. its very common for them to rust at the ends and cause them to bind that will not allow the gate to lift on its own. a click or pop may be heard when the gate is opened or closed.. also if the supports are working right the gate actually moves away from the body when the latch is released. if its stays against the body then try the supports for the gate
Jan 02, 2009 | 2003 Dodge Caravan
Home Fencing Logo
673 people viewed this question
Top Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Home Fencing Expert? Answer questions, earn points and help others
