Question about Air Tools & Compressors
I took apart my x.b.g air gun so I can fix the problem of my co2 letting air out fast then usual nd now that I opened it all of my pieces popped out nd I have no idea on how to assemble it
  • 2712 Answers
SOURCE: how to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Posted on Aug 27, 2008
SOURCE: Reassembly of Air Rifle
Go to www.airgundevelopment.com and scroll down to the link that says crossman valve. I used these pictures to get mine back together. It's not an exact science, but it sure does help.
Posted on Mar 05, 2009
  • 65 Answers
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Posted on Mar 24, 2009
  • 86 Answers
SOURCE: A SOON AS I POT THE CO2 IN MY CROSMAN 357 GUN
the gasket on the gun is probably bad
Posted on Jul 29, 2009
  • 15 Answers
SOURCE: i have a 16-A WELL air soft gun that broke, i need solutions.
Its a well airsoft gun which=**** get a better airsoft gun and you wont have to deal with that ****
Posted on Mar 28, 2010
Where can i purchase the threaded part that goes into the gun and punctures the co2 this is my second request
Direct, eBay possibly or direct from Daisy.
  • Daisy Outdoor Products - Official Site www.daisy.com CO2; Optics; Accessories; Collectibles; Info. ... Winchester Air Rifles ' Where to Buy ... © 2013 Daisy® Outdoor Products ...
  • daisy bb gun parts ' eBay www.ebay.ca > Search > daisy bb gun parts Find great deals on eBay for daisy bb gun parts and daisy ... Vintage Daisy Powerline Model 44 Co2 Innertube Nut BB Gun ... New listing DAISY AIR RIFLES AND BB GUNS ...
  • Air Gun Replacement Parts - AirGun Warehouse www.airgunwarehouseinc.com/repa.html Air Guns. Air Rifles; Air Pistols; BB Guns; ... Whether you are looking for Daisy BB gun parts or you ... we carry a wide range of air gun replacement parts that let ...
  • Apr 01, 2016 | Daisy BB Gun Pistol CO2 BB Gun Repeater...
    How do i reassemble my xbg air ******?
    Really? It's been a year and no one answered his question? What kind of BS is this? This is a common CO2 gun that is sold in many retail stores, and even a quick Google search brings up nothing than this.
    Guess I'm stuck figuring it out myself.
    Aug 28, 2014 | Umarex XBG CO2 Semi Auto Pistol .177...
    Nail gun will not fire a nail each time but only fires correctly ever other time and leaves dimple from the head firing.
    Here are a few tests for you to try. You will need a piece of rubber or coiled up old hose.
    First open side door and remove nails. Tilt gun head down then up again to check if piston is loose in the cylinder. The piston should stay in top position. If piston drops to bottom of cylinder remove head and replace piston oring or apply some layers of teflon tape under oring to expand oring slightly untill piston stays at top but still can be pushed down cylinder (look at the lower bumper to make sure that it is not cracked or missing pieces, if it is breaking up the pieces can lodge within the air path to the feeded piston). If driver piston now stays at top, connect air to gun and with side door open contact gun to rubber firing gun noticing the feeder movement. With very rapid firing of the gun, the feeder should move back and fourth just as fast as the driver moves. If the feeder seems to move slower than the driver moves then check/replace spring in feeder piston chamber. If spring seems strong enough in your opinion then problem is restriction in the air supply to feeder, if air path is clear then replace orings to feed piston. You will need to remove the two 6m allen screws at front of gun and split gun apart to check restriction at the oring sealing these two parts. Sometimes debris traped at oring (white oring) will restrict air to feeder. Good luck.
    Jun 21, 2011 | Stanley Bostitch Nail Gun
    I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
    Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
    Oct 25, 2010 | Crosman Optics
    I have a 16-A WELL air soft gun that broke, i need solutions.
    Mar 13, 2010 | Laser Automatic Airsoft Rifle Gun with +...
    C11 CO2 airsoft pistol asembling porb.
    Check YouTube for something similar
    Jul 05, 2017 | Crosman (4032)
    How to assemble a crosman nightstalker
    Do u still have the gun I've got 1 if u still need information
    Apr 21, 2009 | Crosman (4032)
    My gun fell apart
    sell it to me to fix my gun I need the left grip and the rotory cylinder magazines Do you have these items?
    Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
    Air Tools & Compressors Logo
    Top Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
