Question about In Office Equipment & Supplies
Want to put new ink roller in and do not know how without manual
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
Ink not fused onto the paper.
the newer ink is not good try the good cartridge and use company cartridge
Dec 14, 2007 | Tally T8006e Laser Printer
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
Ink is smearing across amounts. I have put in new one it is still doing it. What do I need to do?
Smearing is usually caused by someone re-inking a roller or ribbon. The roller or ribbon must be replaced - never re-inked or damage can occur. If this is not the case, let me know the brand and model number and I'll try to help
Aug 30, 2010 | Casio Parts Cash Register PC Desktop
I have Lexmark x85printer. Bought new Ink Cartages. Printer Will not Feed Paper All I get is paper jam Clear paper
Either the ink cartridges are incorrectly inserted, and block the paper path jamming the paper, or the paper drive roller got slightly out of kilter when replacing the ink. Sometimes, powering down the printer, manually moving (gently) the printer head halfway from home position, closing the printer and powering it on will clear a roller problem (never tried on a Lexmark, though. It works on Epsons and HPs). If the head doesn't move, though, don't force it. Try instead taking out the ink cartridges and putting them in again, without forcing, and gently wiggling them until they click in place.
If you get the message without any paper in the printer, check the insides for any scrap of paper which could have lodged in the sensors.
Also, verify there is no paper elsewhere in the paper run (paper out tray, etc.). Sometimes the "paper jam" message is a sort of "catch-all" error.
Nov 04, 2009 | Lexmark X85 All-In-One InkJet Printer
How to change ink roller on Sharp Calculator EL-1611H
pulling it upward.
Apr 19, 2009 | Office Equipment & Supplies
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
23 people viewed this question
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
