I have maxwells DVD lens cleaner. When inserted in CD player, it says "no dic". When I insert inDVD player, a menu shows up for cleaning,but won,t do anything no matter what buttons I press
  • 81 Answers
SOURCE: DVD S1000 video player
A new Laser pick up will fix your problem expencsive repair
Posted on Dec 15, 2006
Boggsj
  • 20 Answers
SOURCE: DVD ROM andDVD-RW
Will probably need more information to help you, but do the following. First, right-click your My Computer icon (I'm assuming that you're a windows user) and then click properties. Click on the tab that read "Hardware", and then click the button that says "Device Manager". A list will pop up- scroll down to the line that reads "DVD/CDROM Drives" and click on the plus sign to expand the list- make sure that your drive is listed. If not, right-click on the computer's name at the top of the list and click "scan for hardware changes", it may pop up in a scan. If THAT doesn't work, open your Control Panel and click on "Add Hardware". You will be asked if the hardware is already connected to your computer- we'll assume that's a yes for now. You may be prompted for a disk, or a driver file. If so, it couldn't hurt to go to the drive manufacturer's website and download appropriate drivers (I've never known Windows to NOT detect a drive out of the box, however). Download the file, install or unzip it (varies from file to file) and direct the Hardware wizard to the location of the installed files. If that doesn't work, you can attempt to locate the drive from a list of compatible windows hardware on the next screen. If it STILL doesn't work- Open the case, the procedure varies some from machine to machine, but you'll probably remove two thumb screws from the rear- then remove the side panel. There should be a flat cable attached to the back of your cd-rom drive, about 3 inches wide, and usually gray. One end should be attached to the drive and the other end should connect to your motherboard. If not, connect it- it only goes in one way, has a tooth to prevent screwups. Next, check that the drive is connected to the power supply; a small, one inch wide connector that terminates four wires should lead from your power supply (large box at top left, has huge pile of cables snaking out of it) to the drive. If not, grab a loose power connector (you should have at least one) and plug it into the drive. If all this checks out, make sure that the jumpers are set correctly on the drive. To do so, you'll most likely have to removethe drive from the machine- look around where all the conenctions are to see two small rows of pins (tiny, even) that have a small bracket arranged vertically between the rows- make sure that it is inserted under the label "M" (master) or "CS" (cable select) either should do. Put the drive back in the machine, hook up the flat (IDE) cable and the power cable, and power the machine on. Since it's rebooting now's a good time to check and see if the drive is detected by the BIOS (that screen of crap that whizzes by when you first start your computer). As the machine starts, it may say something like "Press Del to Enter Setup" or F1, or a bunch of other keys, varies from machine to machine. Press it, and you'll go to a screen that lists some of your hardware and computer specifications. Somewhere in there it should list your drive, again depends on the machine. If it doesn't... there may be several other things. I'd have to know what BIOS your machine uses to continue. If none of these things work out for you, there could be other solutions- try using a different IDE cable, use a different power cable, replace the drive (they're rather cheap these days, or borrow one for testing). I'd need more information to continue.
Posted on May 23, 2007
SOURCE: malfunctioning cd player
Did you try taking out that lttle circle thing that you put your cd into.Well,take that out and then clean it.Then,insert it back and it should play your cd
Posted on Dec 15, 2007
  • 16 Answers
SOURCE: dvd player bad disc message
your dvd head (lens) is bad
(1) it needs to be cleaned by a special fluid puted in the cleaning disc or
(2)it needs to be adjusted because it lit vey low illumination (light) during detecting the details of the disc. and this need a qualified technician ot adjust the variable resistor port attached in the lens assembly unit.
Posted on Sep 08, 2008
benwabnick
  • 2404 Answers
SOURCE: Ps3 disc drive not working.
You've done everything I would have done honestly. Take a can of air and blow it into the drive to make sure dirt or dust isn't on the laser which could affect if it sees discs or not.
The better thing to try if you are good at opening up your ps3 and then removing your drive and opening that is to take a damp q-tip with a bit of glass cleaner and clean your laser in the drive gently. Then put the drive back together and hook the cables back up to the ps3. You can leave the cover to the ps3 off for this step. Turn on the ps3 and try different blu-ray, dvd's, music cd's, game discs, etc. If it still doesn't read any of them then either the laser or the drive i bad. If it reads some discs and not others then its a weak laser and the laser would need to be replaced.
If you have to replace the laser or the drive, you can do a search on Ebay and usually find them fairly cheap.
Hope this helps and let me know if I can be of further assistance.
Posted on Jun 21, 2009
No dics display
That means it can not focus on the disc or that you are using the wrong disc type like a DVD in a CD player. Try cleaning the lens.
Dec 21, 2012 | Marantz SA8260 CD Player
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
Cd player not recognized
If the CD drive icon shows up in My Computer then it may just have a dirty laser lens.
That means you have to remove the drive, take it apart and clean the lens.
If it does'nt show up in My Computer then you can restore it with a bit of help from Microsoft. Click the link below and read carefully as it requires you to go in to the registry.
Link
Jan 26, 2012 | Averatec 3150HD Notebook
When i try to play a movie, display shows"no
It is probably the lens, there might be some dirt stuck on it. Use a CD lens cleaner, it is available on any CD/DVD stores. You just basically insert that CD lens cleaner into your DVD player, hit PLAY and then after around 2 minutes, it's done cleaning.
Oct 02, 2011 | Televison & Video
When a dvd is inserted, the message "no disc" appears, what is the cure?
Hello.The problem is not in your television.It is in the DVD player,your player did not read the cd because,either your cd or the lens player is dirty.Now,try to clean the cd first then insert,if the "no disc "appear again try to clean the lens of your player using lens cleaner.Then if the cd and the lens is clean it may play.Thanks
Jul 09, 2011 | Televison & Video
When I put 3 cds in the tray and close it, it goes through all three dics and shows no disc. WHY?
possible solutions:
-insert disc with labelside up
-clean cd/dvd blanc surface with a soft fabric
-use cleaning cd to clean lens
-change pick-up laser or eliminate electronical defect (service issue)
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Mar 27, 2011 | Sony Audio Players & Recorders
If we insert disc it shows bad disc
Please try others disc. If still the same , clean your lens with cd cleaner. If problem persist, replace your lens
Jan 28, 2011 | Philips DVD625 DVD Player
Dics is loading too long and then rejected
then there is a problem with the lens get a CD cleaner to clean the DVD lens and after that if the problem persist then you have no choice other than to change the DVD lens .
Jun 03, 2010 | Samsung DVD-R155
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
