Question about GE Kitchen Ranges
Cannot set the clock on my GE stove no clock pad and I've tried holding the clock for three seconds and does not work
SOURCE: SET CLOCK. TRY TO USE. IT SHUTS OFF AFTER A FEW SECONDS.
I found an envelope with troubleshooting info inside the microwave on the left side behind the front vent. A troubleshooting flowchart was included which indicates that this problem is caused by the high voltage capacitor. I got mine out pretty easy and ordered one from appliancepartspros.com for $55 (which includes expedited shipping. I hope this info helps.
Posted on Sep 12, 2008
vanni7
  • 163 Answers
SOURCE: ge oven clock and oven dont work
Hi!1 your control board is shorted need a new control clock board..Just remove the screws to the top back panel and you will see the the main board easy to fix..Just buy main clock board..Good luck..
Posted on Jan 04, 2009
localwonder
  • 6784 Answers
SOURCE: touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
Posted on Jun 01, 2009
  • 949 Answers
SOURCE: magic chef model# cer3725acw. Using stove top
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
Posted on May 27, 2010
Testimonial: "Thanks for your advice.I tried resetting but I think the part you mentioned will have to be replaced."
  • 15 Answers
SOURCE: reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
Posted on Oct 23, 2010
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
Set the clock to DST, on my GE JRP20 B wall oven
set the clock to a new time:
TIMER/CLOCK Pad
To set the clock, touch this pad twice and hold 3
seconds and then touch the + and - pads. The
time of day will flash in the display when the
oven is first turned on
Mar 22, 2017 | GE Home
Ge profile gas range, no clock pad...how do i set clock. It says hold 3 seconds. What do i hold?
You didn't give a model number, but try the following:
For an electronic clock:
Touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. (Taken from the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Sep 19, 2013 | General Electric Stove/Oven/Range Chrome...
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Clock Display
Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
Oct 08, 2006 | GE Profile JT912 Electric Single Oven
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Apr 05, 2006 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
