Question about Craftsman Garden
Craftsman walk behind lawnmower will not stop
My lawn mower will not stop running. The blade control lever in released but there is no way to stop it from running without letting it run out of fuel
  • Craftsman Master
  • 2,448 Answers
You can stop any lawn mower by taking a screwdriver and touch the engine and also touch the spark plug the same time. this will short out the spark plug and shut the engine down. Use a screwdriver with a plastic handle and you cannot hurt yourself with a shock.
if you have a little handle on the mower handle that is suppose to shut the engine off and it does not work follow the cable and see if you see where it fastens unto the engine. Sometimes these little parts can get out of adjustment.
Posted on Jun 21, 2017
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
SOURCE: walk behind craftsman lawn mower. starts but shuts off
my craftsman 917378490 left front wheel has stopped pulling.
Right front seems ok. Axle is turning on left front from gearbos.
Posted on Apr 13, 2010
  • 54 Answers
SOURCE: lawnmower runs for 2 or 3 minutes then stops
Sounds like you might have a fuel flow restriction, maybe an in line filter?
Posted on Apr 28, 2010
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Craftsman excessive vibration lawn mowers problems
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
I need the manual for a craftsman walk behind model no# 91737068. I didn't get one with my purchase
You can get one in PDF, have them email you one, or contact them and say one wasn't included with the new mower. Here is the PDF version for your owner's manual and a parts list is available that may include the paper printed version as well.
http://www.managemylife.com/mmh/owner_manuals/134119/CRAFTSMAN-Walk-Behind-Lawnmower-Gas-1011592L?brand_name_search=917370680+CRAFTSMAN
May 27, 2011 | Garden
Have never used the lawnmower and the pull cord seems locked or stuck. I can't pull it at all. Is there a button or lever that needs to be pushed before intial use of machine?
There is a brake lever that stops the motor and blade when it is released. This is usually parallel to the handle and would normally be squeezed against the handle when you operate the mower. When released, it is a safety mechanism to immediately stop the spinning blade. You have to squeeze that lever in order to start or run the mower. You can see that lever in the image at the top of your question. Good luck, Al K
May 22, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I'm looking for the manual for the Sears Craftsman II Lawn mower model # 917372850.
Gas-L0709214?brand_name_search=Walk+behind+lawnmower%2C+gas
Attach the above to the other sent link. It was too long to send together
Jul 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Hello I have a Mountfield MPR10071 46" power mower with a Honda GCV 135 4.5 engine just bought it second hand and its fine other than if you let go of the cutting lever it stalls! is it supost to do this ?...
I suspect you mean the OPC (operator presence control) lever? This is a safety feature - if you let go, the blades stop. Since your mower does not have a blade clutch, this means the engine stops.
All walk-behinds HAVE to have this feature if manufactured after (I think) 2002 in the UK - similar rules apply elsewhere.
There's no easy way to disable it - if you tie up the handle so you can empty the grass catcher with the engine running, you will find that you have no way of stopping the engine.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Aug 31, 2009 | Craftsman Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
133 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
