Question about Garden
I FORGOT PUT A SPRING EXT MY LAWN MOWER MOD NO132775SOO I DONT KNOWN WHERE IT GO ONTHE DECK THE SPRING NO932-0384
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
  • 376 Answers
SOURCE: deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Posted on Jun 29, 2009
  • 218 Answers
SOURCE: I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Posted on Jul 12, 2009
SOURCE: Reattach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
Posted on Jul 18, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
How replace tortion spring on toro 22 per pace l/mower
put the deck on the ground
push the deck lever fully forward
use a pair of vice grips done up tight and pull the end of the spring into the hole
Aug 29, 2015 | Toro Garden
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I bought a new deck belt # 954-04062 and its too long. i dont have the old belt. why doesnt it fit? this is what it calls for on the yard machine 38 inch deck
Do you have a large and very tight spring at the back of the mower body?? This needs to be pulled back to the triangle metal piece usually welded to the rear end axle. The spring pulls the entire mower housing back toward the rearend and tightens your new belt. John
Sep 12, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mfirefighter173@aol.comhave a craftsman 17 hp lawn tractor and dont know were to put the spring that engages the mower blades, had to take apart to put in new mandril and cant seem to find were to put this...
There are four pulleys on the deck. Two for the blades, one idler, and one tensioning. The two smaller ones are the idler and tensioning. The tensioning is the one on the right. The post coming out the top of the pulley is where the spring goes, it slides over the top and a clip goes throught the hole at the top of it to retain the spring.
I hope this helps.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Scotts by JD with a 48" mower deck. The spring on the deck has broken. How do I replace the spring? Thanks Rita
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
Jun 23, 2011 | Garden
Toro zreo turn lawn mower... mower runs but won't go when engaged. found a large spring broken?
This spring is the tensioner for the drive belt. visit www.arcolawn.com to look up your model and get the parts shipped to you.
I recommend a hook or rope to install it.
Joe
Feb 12, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Will a snow thrower 42" Mod. no. 486.248392
As long as your deck mounts match up then you should be good to go. You might have to change to a different sized belt though. Other than that everything should be fine.
Feb 07, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Trying to replace ext spring on lawnflite 548 can't get the spring to stretch the last inch.
You don't specify which spring but if you take a piece of starter cord, tie it in a loop and hook it on the loose end of the spring, put in a long screwdriver, a piece of broom handle or anything similar, it will give you a lot more leverage to pull the spring. Once you get it to where it needs to go, you can maneuver it to get it hooked then just cut the rope and pull it out
Sep 12, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN MOWER TO PUT THE BELTS ON THE DECK
Jul 11, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
