Question about Sharp Televison & Video
My sharp tv model# le-52le830u first the power light was blinking +2 short and longer did reset by holding vol- ch^ and power now power light is solid on but tv won't turn on no picture or sound.
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
SOURCE: my sharp 56 inch dlp tv does not turn on. The
the possible problem of your lcd tv is a defective capacito0r on the power supply assembly
Posted on Nov 17, 2009
budmrtn
  • 11361 Answers
SOURCE: SHARP LC-C5255U 52 INCH BLINKING POWER BUTTON, NO
It can be the power supply, backlight inverter board, etc.
First thing to inspect will be the caps in the power supply module, look for caps with leaking/bulging tops, check the DC output voltages, ect.
Learn more about troubleshooting here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 11, 2010
  • 11800 Answers
SOURCE: On a Sharp television model 60LCE77UN when turning
The 2 power light blinks indicate that the power source is in protected mode because the voltage on one of its output rails is abnormal. The 3 blinks of the OPC light indicate that the processor of the mainboard is incapable of loading the firmware of the tv - either there has been a bad command given to the tv (somehow the service mode was accessed and a critical setting has been altered - either by someone by mistake or because the remote malfunctioned) or an exterior cause (a power surge or a power cut during the start of the tv) have damaged the processor.
If it's the first the only way to fix it is to reload the firmware at a hardware level, using the USB connection and a special bootloader. If it's the second one you must replace the mainboard. In either case the dealer's repair shop will have to be contacted, they are the only ones with access to the spares and special programs needed.
Posted on Aug 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Posted on Apr 01, 2012
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
MY TV stopped working ..
It appears that you may hae a power supply issue with your tv. Open her up and identify the power supplyboard and look for overt signs of component failure such as bulging/leaky caps, burnt resistors, bad fuse, etc.
If you can get the part number of the ps board, I would attempt to pick one up on the cheap via ebay or some other outlet and try that.
Mar 13, 2016 | Sharp Televison & Video
How do I get to ch 3 on my sharp 13f-m50?
Try this:
You will have to look around the menu for the reset option to default to ch 3. Be careful. You are in the service mode.
May 14, 2014 | Sharp 25N-M100 25" TV
I have sharp lc-60le810un with a blinking power light
Hold all vol - ch+ & pow will reset. but panel may be bad (led) if you unplug L1 & L2 on power supply set will stay on after you reset it.
Apr 20, 2012 | Sharp Televison & Video
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
29agm2 how to access the servise menu
Hello
Check these proceedings and find out which porocess works with your Sharp TV.
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Mar 22, 2011 | Sharp 29AGM2 29" TV
What is my sharp code
Hello
To get into the service menu do the following.
Unplug the TV
LCD TVs :
After entering to the service manu, goto V-Chip options and Unlock it. You have to reset all V-Chip options after resetting it. OK.
Dec 19, 2010 | Sharp 32C-240 32" TV
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
