Question about Funai Televison & Video
My Funai Tv model LF320FX4F changes channels by itself, the volume goes up by itself and the panel buttons doesn't work
    Master:
  • 604 Answers
Wash with baby wipe the switches,they are stuck in,if you smoke near it,that will be why
Posted on Apr 23, 2017
Testimonial: "I don't have a remote control so im using a universal remote so I haven't been able to use menu functions"
  • johnny rebel Apr 24, 2017
    doesnt stop you from cleaning the buttons and then you may be able to use the menu button on the side
    use a pin to pull each button out a little
Is there update firmware for LF320FX4F Made In Oct. 2013
According to the product support page, Funai has not released any new firmware for the LF320FX4F. Go to http://funaiamerica.com/product/product.php?id=880 and click on the Downloads tab. You can also check for updates from the Support Downloads page, http://funaiamerica.com/support/download.php , by entering the TV model number.
I hope this helps.
Aug 23, 2016 | Funai 32" LED 720p 60Hz TV | LF320FX4F
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
My Funai TV Model Number LF320FX4F Comes On Then Goes Back Off Again
suggest a tv repair shop. if they can't fix worst is they charge you 20.00 not 200.
Mar 03, 2015 | Funai Televison & Video
WHAT TO DO IF MY FUNAI LF320FX4F FLAT SCREEN ...WILL NO LONGER COME ON, AND WHERE TO FIND THE FUSES, OR ORDER A REPLACEMENT POWER SUPPLY?
Try to powercycle the tv by unplugging then pressing the power button and hold for about 1 minute. Once you have done that replug and see if it works. If not, most likely is a mainboard issue. There is a kit available for repair here that you can use that includes all of the parts so you don't have to waste time trying each one at a time. http://digipartsdirect.com/listKits.php?brand=Funai&SId=3
Nov 27, 2014 | Funai 32" LED 720p 60Hz TV | LF320FX4F
Funai lf320fx4f
it should look like
3a8058d6-5d05-4fc8-aa1e-b624777960e9.jpg on computer
Not sure on the cable depends on tv connection for hdmi and hdmi connector on P.C take a photo of each and take with you to store to avoid mistakes
this could be most likely cable
http://www.officeworks.com.au/shop/officeworks/comsol-male-male-hdmi-ultra-thin-av-cable-1-5-metres-cohdmi15st.
However mini connectors are used sometimes so matching the cable could mean looking up computer specifications on type of hdmi used and television specifications on type of hdmi interface used.
Aug 03, 2014 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
162 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
