Question about Fisher Washing Machines
I have a fisher paykel model1wl12 intuitive washer eco i have error code 37 i pulled pump and lines no blockage any help on what i can do next
    Top Expert:
  • 867 Answers
Fault 37 can bean blocked pump but it can also mean faulty pump. these are common to have failed and an easy replacement.
It you check the copper windings on the back of the pump you will most likely see that there is a darker patch, this means the pump has burnt out, sometimes this is not visible but if there is no blockage and it still has the same fault then it's most likely the pump at fault.
Posted on May 15, 2017
Fisher paykel error code 37
check drain pump is not blocked or faulty
Aug 03, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Nov 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My Fisher and Paykel Intuitive eco washer came up with a code:37 we have taken the pump off and the drain hose and blown through it and there is no blockage. When put onto deep rinse as recommended, it...
Fault Code 37 is "Pump Blocked Error" which means for some reason the machine did not drain properly. This can be due to a blockage in the pump such as a lint ball or wire from a bra that got down in the pump, perhaps a safety pin, etc. It also can be caused by objects that get past the pump but become caught inside the diverter valve, which is downstream from the pump. One other thing to be aware of, and this trips people up sometimes- a pump that is failing ELECTRICALLY can also cause the same error. If the pump is overheating and shutting down, the machine will not drain and the control will properly sense that there is still water in the tub. I've suggested in the past that this error be renamed "pump error" because the term "blocked" makes people look for an absolute condition. Since you have cleaned the pump, check the diverter valve for any obstructions.
Jan 06, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 37 F & P Eco IWL16- still pumping slowly
Cleared out the diverter valve (full of lint) then the machine started pumping properly.
Aug 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Machine saying service Code 37
That code is a PUMP BLOCKED ERROR.
This could be as simple as an object caught in the pump or it could be the pump itself has failed. I often see objects caught in the pump. If you can do so safely, unplug the machine, tip the machine back enough to be able to see underneath, and look for the electric pump. You will see a back impeller for cooling the motor windings. Try and turn this by hand, it should turn easily. If it will not turn, then you know there is something keeping it from turning. Be aware that if you pull that pump out with water in the tub, you are going to have a tremendous mess.
You might want to get yourself a service manual for that washer. You can get them from Fisher Paykel Parts:
http://www.fisherpaykelparts.net/115-46/GWL15-WA37T-Service-Manual.php
Hope this helps.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
62 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
