Question about Dishwashers
Dishwasher light blinking that dishes are clean but it won't run any cycles
Is there a reset on dishwashers
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Posted on May 09, 2008
It says in the manual to check the heating element.
Posted on Sep 10, 2008
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
Greg20
  • 149 Answers
SOURCE: Clean light blinks, dishwasher won't start,
turn the power off at the breaker for 10 minutes and check it then.
Posted on Jun 11, 2009
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
Tip
Hard water Calcium white powder build up in dishwasher
Calcium and magnesium is present in a great number of homes today regardless of hardness or softness of the water. Water containing dissolved carbonates of calcium and magnesium can lower the effectiveness of the detergents you use and leave deposits on the dishware and tub of the dishwasher. When these deposits dry they become what some call lime scale.
To remove these deposits there are a number of cleaners on the market today. I will list them in the order of my preference. You can find them near the dishwasher detergents. If you use them read the instructions on the label, but basically you can run a cycle with no dishes and the cleaner. Some of the cleaners like Lemi-Shine can be used with a full load of dishware after you clean the tub. This helps keep the tub clean and deposits off the dishes. If you want a home remedy that seems to work pretty good, put a cereal size bowl upright in the lower rack (no other dishes in the dishwasher) fill the bowl with vinegar and run a normal cycle. The vinegar will wash out and clean some of the deposits away. If residue is still around run a second cycle of the vinegar wash.
- Lemi-Shine
- Finish Dishwasher Cleaner
- Glisten
- Glass Magic
Here are some links to other dishwasher tips I have put together.
Blinking Clean Light
Poor washing on the top rack or noisy
General Dishwasher Cleaning
on Apr 30, 2010 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Clean light blinks
Raise the temperature of your water supply. To reset computer open door,within 3 seconds hit hi-temp scrub then energy saver then repeat this. Close door and latch, push cancell button.
Jun 10, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
