We have Aquos 40D68UT. Picture takes full screen. Problem: cannot seeitems on left side fo shopping shows. Ho do I adjust picture size?
  • 93 Answers
SOURCE: JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Posted on Oct 18, 2007
Coldcut
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
sandrew
  • 2961 Answers
SOURCE: picture is too wide for the screen can`t see all info on program guide on left side
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
Posted on Aug 29, 2008
  • 3 Answers
SOURCE: high def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Posted on Apr 19, 2009
  • 1566 Answers
SOURCE: The sides of the screen are cut off
Please try using the Auto adjust functionality on the LCD TV unit itself.
Posted on Jan 07, 2010
Picture too wide for the screen
Press the "View Mode" button on the remote control. A list of available aspect ratios appears on the screen.
Read more: http://www.ehow.com/how_8668256_change-ratio-sharp-aquos-tv.html#ixzz2yWjUJlEr
Apr 10, 2014 | Sharp LC-32D47UA 32 in. LCD HDTV
Change TV resolutions to view slide shows
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
Jan 23, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Emerson plp42w10a
You are listed under DVD but I am assuming that you are talking about a TV. Most remotes have a button for adjusting the picture size. If not then go into the menu, into video settings and select the picture style there. How it is listed is different for every brand.
Jan 11, 2014 | Televison & Video
How do I adjust image so it fills the screen, side to side and to bottom?
Using the buttons on the screen, bring up the menu.
Then using up/down or left/right buttons navigate to a picture that show a squre that has arrows showing to increase screen size in the approite direction. Select this picture and use the arrows to either increase or decrease size.
Your timeous rating of this solution is much appriciated.
Thanks
Nov 01, 2010 | LG W2243T-PF Monitor
PIcture does not fit on TV
TV must be set to zoom, take the zoom setting off
Mar 06, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
High def picture is cut off on the sides
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screene size
Ok this is called Blooming, this is when the signal intesifier becomes overloaded and the signal becomes overenergized and thus unviewable. This is not an adjustable proble even thoug for a time you can force the picture "shrink" but this is not a fix, it just hides the problem. I suggest that you fide a shop on FixYa that can look at you set and diagnose which components are at fault. You can also take the unit to a Tv shop in your area if that is easier for you.
Sep 08, 2007 | LG 17LX1R 17 in. HD-Ready LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
