Question about Bosch Washing Machines
I have a Bosch Axxis+ compact washer and need a dryer to go with it. I don't want a ventless dryer which is all Bosch makes anymore. Is there another dryer that is compatible with my washer?
The washer needs to plug into the dryer and be stacked on top.
  • 105 Answers
SOURCE: I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Posted on Feb 05, 2009
  • 7 Answers
SOURCE: asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Posted on Feb 25, 2009
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
  • 9 Answers
SOURCE: i am going to relocate a bosch axxis washer and
yes you need to use the two bolts that were given to you when you acquired it to block the drum during transport (otherwise you could damage the axcel)
Posted on Jul 27, 2009
  • 5 Answers
SOURCE: what size circuit do I need for the bosch axxis
If it is a Bosch WTE86300US. The instruction manual available through the bosch website says 30A 3 or 4 pin
Posted on Aug 18, 2009
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Clean reg flashes
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Axxis Series WTB86201UC 24" Ventless...
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Apr 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
What size circuit do I need for the bosch axxis 24 ventless dryer
Aug 18, 2009 | Dryers
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
