Question about John Deere Garden
2011 John Deere x729 Cracked transaxle housing below filter, machine dumped all the hydro fluid out. JD dealer says 8200 plus labor. Anyone have a similar problem? Thanks for the time.
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Apr 25, 2017
How to remove transe axcel john deere x300r
Try you tube Go to site. On the line Remove transaxle from JD------------
Sep 04, 2016 | John Deere 300 / 316 Hydrostatic Tractors...
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
What hydro fluid does a john deere 333d skid steer use
333D uses a variety of oil for the hydraulic system. Primarily 10W-30 Torq-Guard Supreme or 10W-30 Plus 50 II
EXCEPT: If your machine was equipped with the cold start package, it will use either Plus 50 II 0W-40 or Hydrau XR (Hydrau XR can be added to Plus 50 II 0W-40 in any ratio, ie. topping off 0W-40 with Hydrau XR is okay)
Dec 08, 2015 | John Deere Garden
J deere 310 leaks between the hydraulic filters there is silonoid between them
Wipe down and clean the filter, filter housing and hydralic lines, run your jd until you see hydraulic fluid, stop the machine and look to see where it originated from... If it's from the filter, change the filter, make sure the old oil rings are no stuck on the housing, and there's a o ring that comes on the new filter, pre lube the filter o-ring and install,,, if it the hydralic housing or pump, check for hair line cracks, check the threads on the filter head on the housing for cross threading, and last but not least and the greatest possibility... The hydraulic line connections to the filter housings and pump... The will most likely be the issue... Spray brake cleaner all over the connections to clean them run the machine and look to see which one is leaking... When replacing the hose connections, replace with a quick connect hose end to save on value time and efforts in the future.
Oct 13, 2013 | John Deere 420,1020,2010,2020,2510,2520...
JD 4310 tractor hydro problem
Jeff I am having the same problem. Have you found a fix for this yet? your post is right on but for some reason we are the only two withthis problem and my local jd dealers have never seen this. , Brent
Jun 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
Can i have a belt diagram for a john deere stx38 please , thanks pete
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Click on the above link then do a "model search"
click on which model (either yellow deck or black deck)
alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or you can try the link below.You will need to sign up(free I think)
http://www.pdfph.com/pdf/john-deere-1999-stx38-hydro-deck-belt-diagram/
The link below has a picture of the belts on a yellow deck.
http://www.askmehelpdesk.com/tools-power-equipment/installing-belt-jd-stx38-hydro-385391.html
May 16, 2011 | John Deere Garden
John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Apr 03, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
