Question about Craftsman Garden
My craftsman riding mower has a electric clutch to engage the deck drive. it was working one minute, then it just stopped working. What could be wrong?
    Master:
  • 923 Answers
The electric current quit flowing ... obviously. Is there a wire broke? is the switch bad?
Posted on Apr 23, 2017
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
I was mowing grass with my 21 hp 42 in electris start and my blades stop working
check for belt coming off blade drive......check the power to blade engage switch...... check electric clutch on front of motor
Sep 10, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 HP Lawn Tractor PTO will not engage
did you break the deck belt?did you over load the electric clutch and blow the fuse?
Aug 06, 2012 | Garden
Craftsman mower deck engaging intermitantly
I believe I would start by looking at the grounding for the solenoid(clutch) sounds like that it may be intermittent. Or the spring assembly that physically engages the assembly on the deck my be dirty or need a lubricant and a cleaning or both. Good Luck
Jun 04, 2012 | Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 22 hp. When I engage the mower deck it seems that there is a problem with the electric clutch. The deck does not engage and there is an audible hissing sound from the pulley just under the...
Make sure that the clutch is being fed 12 volts or the clutch will not engage. Also make sure that the belt is not stretched and worn so bad that the clutch pulley will not grab it. Good luck. donnyb60
Mar 21, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
