Question about Hoover Vacuums
My Hoover F7452900 uses up the detergent in about 30 seconds and doesn't use any water. What can I fix?
  • 923 Answers
The water and the soap are supposed to mix as they are dispensed. Check for a leak or crack anywhere in the water line. Any crack would make the vacuum-operated delivery of water quit working!
Posted on Apr 23, 2017
Hoover F7425-900 SteamVac V2 Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
My Hoover max extract Spin scrub FH50220 is leakiing bad what can I do
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Aug 10, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Steam Vac F7452900. I've read the tutorial about how to replace the brush turbine but the pictures are of a different model. I've removed the screws from the underside but my...
I have an F7427-900 but try taking a flat headed screw driver to the black plastic on the front. I gently tried it on mine and it popped up no problem.
Sep 05, 2011 | Hoover V1 SteamVac SpinScrub Vacuum
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
