Question about Refrigerators
Side by side. Freezer seems to be not working sporadically. Food "unfreezes" then refreezes. Ice cubes get wet then refreeze hard. Occasional loud hum. Refrigerator side is ok.
lojacksdad
  • 121 Answers
SOURCE: bottom freezer, ice cubes melting and refreezing.
defrost timer saying off to long
Posted on Apr 17, 2009
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
Bat1956
  • 585 Answers
SOURCE: really loud humming noise and freezer is defrosting/refreezing
Connect only to an outlet, do not use an extension cord. If you really must use an extension, make sure it is capable of handling the load. Should be a 16ga minimum, 14ga preferred and not exceed 25 feet. If you are having this issue while plugged directly into an outlet, perhaps the circuit is weak, and you should try another outlet.
Other possibilities include: a short-cycling thermostat. This is when the thermostat tries to kick the compressor back on too soon after the last running. OR Your compressor is on the way out. Sometimes the installation of a "Hard Start Kit" will aid a failing or stubborn compressor. If you've eliminated all else, consult an appliance servicer to buy the hard start kit. They typically are a universal fit, and come with instructions.
Posted on Jul 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Posted on Aug 14, 2009
SOURCE: Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Posted on Feb 15, 2010
Freezer thaws and refreezes
HI.DO BASICS FIRST .CLEAN CONDENSER UNIT FIRST THOROUGHLY.INTERMITENT FAULT IS ALWAYS A BIT DIFFICULT TO DIAGNOSE.TRY IT IF OK U HAVE CRACKED IT BUT IF SAME THEN C WEATHER THE MOTOR AND CON/UNIT IS WARM WHEN DEFROSTING IF COLD IT COUD BE A LAZY DEFROST TIMER OR T/STAT THEN HEATER AND FAN.GOOD LUCK ALI
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Our 2 1/2 year old GE side by side frigerator has worked fine in the past, but now the top part of inside the freezer thaws part of the time. The ice cubes partially thaws then refreezes into a solid cube,...
hey i got disconnected do me a favor AND CLOSE OUT OF THE CHAT SESSION AND PLEASE RATE IT FOR ME I WILL FINISH UP EVERYTH ING FROM HERE SO YOU WONT HAVE TO PAY FOR IT AGAIN
Apr 24, 2010 | Refrigerators
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 13, 2009 | Refrigerators
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
