Speakers stopped working
I plugged in a set of headphones and when they did not work I unplugged them and my sound went off an TV
Indian Guru
  • 32 Answers
SOURCE: Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Posted on Apr 20, 2007
SOURCE: Problems with HP JBL Platinum Computer Speakers
yes you're right. It's a input not a output jack. I discovered it some time ago. The problem is the symbol on it seems like an headphone...
Posted on May 24, 2008
  • 42 Answers
SOURCE: Gateway laptop internal speakers do not work.
Unplug your headphones if you have not already.
Open device manager. You can do this by right clicking on your "My Computer" icon on your desktop and then selecting properties at the bottom of the menu that comes up, or by going to Start>Settings>Control Panel, and then opening the "System" icon.
Once the system properties tab is open, left click on the hardware tab. Now left click the Device Manager button.
On the device manager window, look for an entry that says "Sound, video and game controllers". Left click the + box directly to the left of this line. It will open up any devices you have in this category. Within this list, your sound card device should be listed. It may say something like "SoundMAX Integrated Digital Audio" or something similar.
Right click this device and left click uninstall. It will prompt you if you are sure you want to do this, tell it yes/ok and the driver will be uninstalled at this point, leaving ou with the device manager open still but without your sound driver listed.
Now, close all of your open windows saving any work you may have open, and reboot the PC. Upon reboot, the system will automatically reinstall your sound card driver. It may prompt you if you want to do this, just tell it yes/ok as you need to, to continue installing this driver.
Once this is complete, your sound should be working normally again.
Posted on Jan 17, 2009
SOURCE: Built-in speaker in Mac doesn't work (red light!)
I took a safety pin and put it in the notch inside the headphone jack input. notch is located at 12 o'clock about 1/8th inch in, (this is an important step, other steps are no good until red light is off) the red light went off (Be patient this step may take time) still no sound, I then went to Audio MIDI setup (Should be located in Applications/Utilities), go to Audio in menu bar (at very top of computer screen) and selected 'open Aggregate Device Editor,' clicked on the + to add a device I then had a few options show up in the lower [Structure] portion I clicked on all the 'Use' boxes and the built-in output bubble selected done. I then Selected Configure Speakers in Audio MIDI setup and I can test my left and right speakers individually, they put out a fuzzy test sound, pressed done when finished. They still didn't work so I set Default out put to the Aggregate Device I created, then turned on Itunes and it was working fine I just could not control the volume from the F3, F4, & F5 buttons so I went to sound in system preferences and made sure the built-in Output option was selected. I was then able to control the volume. The red light in headphone jack input may come back on if anything is inserted inside, just mess around with the notches inside till it goes off. Hope it works as well as it did for me. Good luck and please feel free to quote me and share this solution with others.
Posted on Jan 22, 2009
SOURCE: no sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Posted on Feb 01, 2009
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
How does it work with tv
Normally, when headphones are plugged in, the TV speaker is automatically muted. To use the headphones, leave the TV volume at a normal level, and the speaker sound should stop when the headphones are plugged in.
Dec 03, 2014 | Televison & Video
I have a Dell W3706MH tv monitor and the sound just stop working. I unplugged the speakers and plugged them back in still no sound. I unplugged them because it was making a loud buzzing and popping noise...
If possible, plug the speakers into a portable device such as a cell phone, portable cd player or a tv that is equipped with a headphone jack (if speakers have the jack). If not, if the speakers have the red and white, ref and black or black and white male end connectors, plug them into a tv or dvd\blue ray player. If you get sound they are good, and you need to adjust your sound options on your computer. Let me know if this helps\works. Also, not all speakers are compatible with all computers and must have the same sound level equivalence to the device they are being used with. i.e. Ohms etc.
Aug 29, 2014 | Televison & Video
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
Oct 05, 2009 | Dell A525 Computer Speakers
Speakers have stop having sound
1. Please plug in a set of speakers or headphones known to be in working order.
a. If the known-to-be-in-working order speakers or headphones work, your existing speakers are faulty.
b. if the known-to-be-in-working order speakers or headphones do not work, your existing speakers are fine, and your sound card is faulty.
Mar 29, 2009 | Computers & Internet
No Sound
try a diffent set of speakers or headphones always use the green port
May 01, 2008 | Audio Players & Recorders
AKAI PT5492S
make sure it's not muted. you can also change from lift to right speakers. you may have burned up the audio driver amp.
Apr 22, 2008 | Akai PT5492S 54" Rear Projection...
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
