Question about Coffee Makers & Espresso Machines
The K cup leaks grounds as soon as you insert
2 Suggested Answers
  • 78 Answers
SOURCE: Grounds in cup;water leaking.
Could be a couple of things. Clean out the channels of the coffee machine. Clean out the upper pick that pierces the K-cup. Sometimes this can start with a defective K-cup...yes, it happens.
Posted on Nov 09, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Coffee grounds in the coffee
There are a couple things that could cause that, that I experienced:
1. I found that the water injection needle sometimes gets dirty. Coffee grounds are in it and cause the water to go over the top and wash coffee past the k-cup into your coffee cup.
You can use a paperclip to clean out the needle.
2. There is a whole in the k-cup somewhere or the lid is not properly / or strongly enough glued to the k-cup. The water-pressure then pushes coffee out of those holes around the k-cup into the coffee mug.
3. The plastic insert where you put the k-cup in is dirty itself (I have to clean it every now and then).
4. The coffee in the k-cup is ground so fine that it gets pushed through the whole on the bottom that is being punshed for the water to escape.
Feb 27, 2015 | Keurig B60 Coffee Maker
Kerig Vue will not come out of the preheat mode
This worked for me: 1) Turn off machine 2) Remove lower tray. It pulls right out. make sure it is clean. RE-insert. 3) Remove upper tray. It's a little trickier, put it also pulls down and out. Mine was full of coffee grounds. I rinsed it out with tap water. 4) Replace upper tray. 5) Take a used V-cup and take the foil and filter out leaving only the plastic tray. Clean it thoroughly of coffee grounds with water. Replace it in the V-cup insert. 6) Power on the Vue. It should come on pretty quick and say " Ready to Brew" run 6 to 8 oz through with just the blank V-cup. This will clean out any remaining debris. 7) Now put in a new V-cup and brew your coffee!
Oct 04, 2012 | Keurig Vue Brewing System
DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
Jul 30, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
My van is currently leaking antifreeze thru the back of the engine not much but when i look under i see about a quater of a cup on the ground. a lifted the van up but i cant see were the leak is coming...
There is a Freeze plug. Located at the rear of the engine.Also approx six more on the block. You will need to remove the tranny to replace it, The replacement part costs $5.00 The labor should be about 2-300 Go to a local tranny shop not AAmco They will rip you off. Change all the freeze plugs at the same time. If one is going out the others will follow soon. Do it soon. John
Jul 21, 2011 | 1998 Ford Windstar
My Keurig (one year old) does not brew a full cup (I have it set for the largest cup setting) and it only brews approx 4 oz. then stops.?
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Oct 03, 2010 | Keurig B100 Coffee Maker
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Apr 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Feb 10, 2010 | Bunn 10 Cup Home Coffee Brewer
Nov 05, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
