Question about Bernina Sewing Machines
What does the brown line indicate along the length and width on my Bernina 630 computer screen
  • Bernina Master
  • 11,177 Answers
Is it the stitch length and stitch width indicators?
Perhaps a manual would be helpful:
BERNINA artista 630 Support BERNINA
Posted on Apr 26, 2017
How can I change width of stitch
width has no way to be widened only length can be changed. try setting on zigzag and then to the max length on stitch.
Aug 02, 2017 | Sewing Machines
The zigzag stitch will adjust width but not length
If it's a mechanical Bernina, it could be some of the lever mechanics have seized from old, dry oil. You can try liquid Tri-Flow Synthetic Oil--a couple drops where metal rubs on metal to see if it loosens things up. Applying hot air from a handheld hairdryer will help speed it up. The other possible alternative is that something is no longer attached to the knob/lever.
If it is a computerized Bernina, you should probably take it for service.
Aug 04, 2016 | Bernina Sewing Machines
How do i alter the stitch lengthbon Bernina 1080
The bottom dial on the right of your machine is the stitch length selector. The dial at the top right is the stitch width selector.
Dec 05, 2015 | Bernina Sewing Machines
How do I enlarge decorative stitches on a Bernina 830?
The only way (that I'm aware of) to enlarge decorative stitches is by increasing the stitch width and the stitch length. You might try a thicker thread that will cover more. The only other way might be to use embroidery software.
May 09, 2015 | Bernina Sewing Machines
Can I sew on buttons?
Set the zig zag the width of the holes. Do you have a button foot looks kind of like a half moon
Apr 25, 2015 | Bernina Sewing Machines
How do I satin stitch h on a Bernina 1130s limited edition?
Satin stitch is a very wide zig-zag stitch with a very short stitch length. I do mine by dropping the feed dogs and guiding the material through by hand (a lot like darning).
Jan 30, 2015 | Bernina Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
