Question about Geberit Home
Where is the shut off valve on a geberit wall hung toilet? i need to locate an access panel
  • 34 Answers
SOURCE: Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know.
Posted on Feb 05, 2009
  • 297 Answers
SOURCE: Cheviot Wall hung toilet flush valve replacment gasket
try a plumbing supply co. they may help you
Posted on Jul 14, 2009
  • 39 Answers
SOURCE: Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Posted on Aug 05, 2009
  • 12744 Answers
SOURCE: Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Posted on Mar 02, 2010
  • 299 Answers
SOURCE: TOTO toilet Gmax fill valve
You need Korky Part # R528 available at Home Depot. Instructions are on the package and it takes just a few minutes to change it.
Posted on Apr 18, 2010
The tiles behind my wall hung geberit tiles are cracking and the toilet seems to be moving a little. Ian afraid it is going to pull out of the wall. It has been there for 10 years but is a spare washroom...
Never herd of wall tiles cracking. If you have access to the underside of the bathroom (via basement ceiling), you may want to check of the wall(s) has proper support for load or a non-supported floor plywood joint may have been installed the wrong way/not supported properly. You should be able to see the nails coming through the floor plywood where the wall(s) is located above. You may have to add blocking and/or brace(s) with joist hangers for support as required. Interior wall studs may also been spaced at 24"c/c instead of 16"c/c if the wall tiles were not installed by the builder not accounting for heavier than normal load.
If by chance the washroom is in the basement::
  • Non-load bearing walls (interior non-loading will be supported by the slab.
  • Load bearing walls will be supported by footing foundations
As for your toilet moving: the wax gasket may need replacing if not seated properly (rocking). If it just seems a bit loose, try to just tighten the flange bolts on both sides of the bottom of the toilet after removing caps. If no spacers are present between the bolts and the ceramic, they need to be there to not crack the base or reduce the chance of over-tightening that would do the same. There may be water coming from a shower that's close by or from the sweating of the tank in the humid summer months.
If the ceiling are closed for access below, you have the choice of tackling the job from within the bathroom by removing the some of the plywood floor to inspect the problem OR by the ceiling below. I would should the ceiling below if it was me.
Good Luck!
Mar 01, 2015 | Home
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
How do you adjust the fill level for a geberit fors inlet valve
A "Geberit FORS Inlet Valve" is not a dishwasher part. It is a fill valve made for a toilet cistern. You adjust it by removing the valve, removing the blue "locking clip" on the lower part of the valve body, then rotating the valve body to make it longer/shorter (and hence raise/lower the height of the large float body on the side of the valve). Once done, reinsert the lock clip, and reinstall the valve in the toilet tank. You can see how to adjust it at this link
Jul 04, 2012 | Home
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
Aug 23, 2011 | Duravit 111335001 Geberit In Wall Carrier...
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
Why does sani best need to be 3 feet from stack if it already has to shoot up at least 6feet and over 2feet
just to prevent against cross flow - you dont want effluent from the stack entering your saniflo pipework- to ensure against this with your configuration, i would fit a non return valve on the horizontal inline, preferrably with a cleanout access just in case!!
Nov 06, 2009 | Saniflo SaniStar SaniPack Wall-Hung...
My toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Jul 02, 2009 | Home
Jan 11, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Home Logo
70 people viewed this question
Top Geberit Home Experts
john h
Tom Chichester
Are you a Geberit Home Expert? Answer questions, earn points and help others
