Question about Electrical Supplies
What does a 5500 watt goodwyn robin generator weigh ?
    Top Expert:
  • 23,148 Answers
Already posted that one.
Posted on Apr 23, 2017
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
Physical location of control board on an Onan 5500
It is right behind the start switch. There is one bolt that holds your start switch housing down, remove it and the housing. You will see the P1 connector with a lot of wires plugged into the control board
Dec 03, 2013 | Watts Onan Portable Generator - 4000 ,...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
Robin RGX 5500 Generator owners manual
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/GS0597B.PDF
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/PUB_GS0597B.PDF -
There you go one owners manual.
Sep 26, 2010 | Garden
Tappet clearance and spark plug gap on 5.5 hp ohv engine, i have a generator which runs on natural gas made by china i just want to know the gap of tappet and the spark plug gap
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Jan 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
