The blanket is blinking on one side what can we do?
When I plugged in the cord to the blanket, it displays a continuous blinking of the letter F
Sunbeams - blinking "F" means that the connection to the blanket was loose. Make sure you give it a good push to get the piece fully engaged.
Nov 18, 2014 | Sunbeam Twin Electric Auto Heated Blanket-...
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
Dual control electric blanket doesn't get warm, the controllers just blink
The problem can be caused by a defective heating element in the blanket.
Nov 24, 2013 | Sunbeam Electric Blanket Dual Controller...
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Jun 25, 2011 | Vacuums
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
My dual control electrc blanket won't stop blinking, and it won't
Try unplugging it from the wall, waiting a few seconds, then plugging it back in.
If that does not work, try either turning the blanket over OR swapping the controls to the opposite sides, then unplugging it from the wall for a few seconds, and plugging it back in.
Nov 26, 2008 | Heating & Cooling
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
