Question about The Health & Beauty
I need to replace the electrical power cord - The Health & Beauty
I need a new electrical cord for my crock pot.
These should be available from any electrical shop. Very often even kettle cords will fit crockpots. Take the old cord with you when you shop.
Nov 21, 2015 | Crock Pots & Slow Cookers
Why can't I find a replacement power cord for my Rival electric skillet Model SS 120
What is the model of the cord you need. Also what is the wattage of you skillet?
Jan 29, 2015 | Rival Kitchen Appliances - Others
I need a new power supply cord for my Cafe Collection electric skillet Model SY-101K or LPH-5
try an appliance repair shop as most have replacement cords for most appliances
contact the manufacturer on line in their spare part section and order one
Jan 23, 2012 | Wolfgang Puck Kitchen Appliances - Others
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    Braun Syncro 7505 Shaver, Need Power Cord.
    If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
    http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
    If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
    Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
    Replacement Power Cord
    You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
    Dec 28, 2008 | Le Chef Electric Shabbos Hot Water...
    New Plug and Cord for Wolfgang PuckĀ® Reversible Electric Grill/Griddle
    I also need a replacement electric cord for the Wolfgang Puck Reversible Grill. Please let me know if you are able to locate one.
    Oct 19, 2008 | Wolfgang Puck 781698 Indoor Grill
    Health & Beauty Logo
    18 people viewed this question
    Top The Health & Beauty Experts
    Megan S.
    Megan S.
    Level 1 Expert
    Are you a The Health and Beauty Expert? Answer questions, earn points and help others
