Question about Electronics - Others
4GB Sandisk Cruzer
I have a 4GB Sandisk Cruzer and I have no idea how to make it bootable so I can transfer my recovery disk files on it so it can fix my computer.
I need help with step by step instructions because I look at a couple of websites and I have no idea what to do and how to do it.
MY COMPUTER: Acer Aspire One (Model ZG5 if that helps)
USB FLASH DRIVE: 4GB Sandisk Cruzer
PLEASE HELP ME!!!!
  • zzmmalika Jul 26, 2009
    how do u create a bootable floppy disk on Windows?
  • 69 Answers
Hi this is the link:
http://www.bootdisk.com/pendrive.htm
for step by step.. get back to me if you have any other problems.
Posted on Jul 24, 2009
  • Fernando Torres
    Fernando Torres Jul 26, 2009
    Hi the same www site can show you how to boot with floppy .. but if you still have windows os running. just format a floppy disk and put a tick under MS DOS Startup Disk by format options
Hi i have a 4GB sandisk cruzer micro and i use it for my xbox360. I used 1.4Gb on it and i want to transfer some songs from my computer to it and it says i have 3.18GB FREE on it but when i move a song to...
you could add your game to a zip file
then add more music
also
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Feb 11, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a 4gb Sandisk cruzer and when i plug it in it says there is only 1.83 gb available but there are no files shown, how do i erase the whole drive so i can use the full 4gb's
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
if you still want to format this drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 05, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
4gb Sandisk Cruzer USB drive on Windows XP SP3 When transferring over large files (1-3gb) I get an error message after about 3-4 minutes of transferring (roughly halfway through or near the end of...
WinXP uses its own driover for USB drives like this so as long as you have the latest updates installed that should be OK.
Make sure you are doing nothing else with the computer when transferring the file.
Check and make sure you have at least double the amount of free hard disk space as you are transferring.
Reformat the flash disk completely and tyhen run a checkdisk on it specifying to report and fix all errors.
Try defragmenting the hard drive so temporary files can be laid down contiguously.
See if there is a BIOS update for your motherboard.
May 17, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Recovery Disk
you can make you flash drive bootable.. the problem is that it might not necessary copy over the recovery cd files properly. Here is a link that can help you: http://www.bootdisk.com/pendrive.htm
Jul 24, 2009 | Computers & Internet
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Mar 10, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Why can't I put a 7gb video on my 16gb Cruzer
I think I know what your problem may be. Check to see how the drive is formatted. Drives formatted with FAT32 cannot transfer files 4GB or larger. Try reformatting the drive to NTFS.
1. Open My Computer
2. Right click on the drive
3. Select Format
4. Under “File System” change it from FAT32 to NTFS
5. Check quick format
6. Click start
I have not tried this yet but if that does not work try this:
1. Right click on My Computer and select Manage
2. Click on Storage
3. Click on Disk Management
4. In the right pane right click on the drive letter assigned to the San Cruz
5. Select format and choose NTFS
I hope this helps. Good luck!
Jan 03, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cruzer micro 4GB can't be accessed
http://files.filefront.com/LLFsetup2361181exe/;7310930;/fileinfo.html
This software will low level format your drive back to factory settings.Just like when you first got it. If your machine racognizes the drive but you get an I/O error this is the fix. GOOD LUCK !
May 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Needhelp in the operation
you can use it to store files, downloads, music, pictures etc. or to transfer files from your computer to a new one. if your computer doestn print you can connect the usb to a compueter that does and print documents from there. all you have to do is have a working usb port and you can begin.
Apr 12, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
184 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
