Electrical power cord replacement - Office Equipment & Supplies
I need a new electrical cord for my crock pot.
These should be available from any electrical shop. Very often even kettle cords will fit crockpots. Take the old cord with you when you shop.
Nov 21, 2015 | Crock Pots & Slow Cookers
I need a replacement power cord for the Worx series electrical snow blowser. kc
FIND A NEW CORD, SAME 3 OR 4 WIRE. 12, 16 SIZE. PUT NEW WIRES ON SAME TERMALS
Dec 05, 2014 | Garden
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    Cartridge error 1102
    Cartridge Error (1102, 1203, 1204, or 120F)
    1. Remove the print cartridges, and close the cartridge carrier lids.
    2. Disconnect the power cord from the electrical outlet.
    3. Reconnect the power cord to the electrical outlet.
    4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
    5. Reinsert the print cartridges.
    If the error does not reappear, the problem has been corrected.
    If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
    5. Reinsert the black (or photo) print cartridge.
    6. If the error:
      • Reappears, replace the black (or photo) print cartridge with a new one.
      • Does not reappear, reinsert the color print cartridge.
    7. If the error reappears, replace the color print cartridge with a new one.
    Jun 16, 2011 | Office Equipment & Supplies
    My printer will not come on at all. i have the adapter in to the wall jack but nothing happens. i have checked to ensure the wall jack works.
    Solution one: Make sure the electrical outlet works
    Unplug the power cord from the electrical outlet.
    Plug another appliance into the electrical outlet to make sure the outlet works.
    If the electrical outlet does not work , plug the product into another outlet that does work.
    If the electrical outlet works, but the product still does not turn on , continue to the next step.
    Solution two: Make sure the power supply is compatible with the HP product
    The term power supply refers to both the power module and the power cord.
    NOTE: To make sure that your product and power supply are compatible, HP suggests you use the original power supply shipped with your product.
    Example of a power module Example of a power cord
    NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module.
    Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product.
    Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product
    If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product.
    WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
    Solution three: Reset the power module and test the power
    Step one: Reset the power module
    The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    Unplug the power supply from the rear of the product.
    Unplug the power cord from the electrical outlet, power strip, or surge protector.
    If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    Wait 15 seconds.
    Reconnect the power cord to the power module.
    Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    Check to see if the power module has an LED.
    If the power module does not have an LED, continue to the next step.
    If the power module has an LED, check to see if the LED lights up.
    If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
    If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-One
    Follow these steps to test the power on the product.
    Reconnect the power supply to the rear of the product.
    Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
    Figure 1: Press and quickly release the Power button
    If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
    If these steps resolved the issue , there is no need to continue troubleshooting.
    If the issue persists , see the next step.
    Solution four: Test the power with a compatible power cord from a different product
    If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
    If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
    If the product does not turn on with the alternate power cord, continue to the next step.
    Solution five: Service the HP product
    If you have completed all the preceding steps and are still experiencing a problem, service the product.
    Mar 26, 2011 | HP PSC 750 All-In-One InkJet Printer
    I press the power button but the machine does nothing. It's pluged in and the lcd lights up
    1. Unplug the power cord from the electrical outlet.
    2. Plug another appliance into the electrical outlet to make sure the outlet works.
      • If the electrical outlet does not work , plug the product into another outlet that does work.
      • If the electrical outlet works, but the product still does not turn on , continue to the next step.
      • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
        1. Unplug the power supply from the rear of the product.
        2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
        3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
        4. Wait 15 seconds.
        5. Reconnect the power cord to the power module.
        6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
        7. Check to see if the power module has an LED.
          • If the power module does not have an LED, continue to the next step.
          • If the power module has an LED, check to see if the LED lights up.
            • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
            • If the LED lights up, continue to the next step.
        Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
        1. Reconnect the power supply to the rear of the product.
        2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
        • If these steps resolved the issue , there is no need to continue troubleshooting.
        • If the issue persists , see the next step.
        Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
        • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
        • If the product does not turn on with the alternate power cord, continue to the next step.
        Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
    Power could not start by pressing power button but power is coming as the blinking is done for once when connected to power
    Dec 30, 2010 | HP DeskJet F380 All-In-One Printer
    Can not get hp 1210 to start -power is getting to machine but it will not start..
    1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
    2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
      • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
    Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    4. Wait 15 seconds.
    Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
    Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Error1102
    6. If the error:
    Dec 18, 2009 | Lexmark C533DN InkJet Printer
    Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
    The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
    If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
    It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
    If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
    Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
    19 people viewed this question
    k24674
    jasbo
    jasbo
