Activate my card please ,my num is 98260133 6232300517
How do I set the numb lock key to activate at startup on gateway laptop with widows 7
Often, there is a setting in the BIOS.
Other than that, I have not experiments with it.
Here are some suggestions for XP and Windows 7
Turn NUM LOCK on at start up
For Windows 8, there are some instructions:
Num Lock not turned on when booting Windows 8
Aug 19, 2014 | Computers & Internet
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
I have an aspire 5532 num lock will not activate. I have tried FN and num lock together. The orientation operation works but the numerals will not show. The num lock is labeled white with no FN blue...
If the word NumLk (or NumLock) is written is white, then you will only need to press Num Lock key once to activate Num Lock
Usually software settings do not affect Num Lock or Caps Lock keys and should always work, unless there is a problem with that specific key.
Sep 19, 2011 | Acer Aspire AS5520-5537 Notebook
How to activate the num keyboard? Can´t find the Num Lock key.
Welcome to fixya,
The num lock key is on the top right of your keyboard where you see the numbers.
Hope this Helps.
Dec 18, 2010 | HP Pavilion dv7-1130us laptop
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
