Question about Samsung HLP5067W Television
Color wheel broke apart replaced that put in a new lamp and it still wont tyrn on. Lamp light blinks for a few minutes then all three front leds come on steady where should i look next
  • 261 Answers
Ok so first of all regarding the color wheel, did you identify if it was one with silver or gold bearing, because if you boguth the wrong one, it's not going to work... second of all... So if you bopught the right color wheel, here's the next thing, it might be an issue with your ballast, which is also part of the light engine system, so if it's not working you will not have an image, actually if I were you, discountdashmerchantdotcom ask for the free troubleshoot, that way you can explain every detail to those guys, but like I said, if you got the rigth color wheel, it's most probable that the issue is with your ballast
Posted on Jul 24, 2009
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Ml-r4667w timer,power,stanby/high temp leds on front panel blink replaced lamp w/original pt
If you replaced the lamp and it illuminates and three blinking leds still appear the you have a bad Color Wheel.
Apr 07, 2010 | Samsung HL-R4667W Rear Projection...
My hls5086w shuts off after 20 seconds and all three light flash is this the bulb?
Could be the Lamp. But first unplug the set wait 10 seconds the plug the set back in and turn on the set while looking at the rear Lamp Door vent slots. If the Lamp Illuminates then the lamp is probably good. You might try installing a new lamp since I do not know when and if you have ever replaced the lamp. If you have never replaced the lamp then it is time for a new one. If after replacing the lamp and the set still shuts down with three blinking leds then you have a bad Color Wheel.
Apr 06, 2010 | Samsung HL-S5086W 50" HDTV
No picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
May 18, 2009 | Samsung 61" Slim-Depth DLP HDTV
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung hln5065 picture issue
If all 3 lights are blinking on Samsung DLP it means your lamp is burnt out or has issues. The manual says replace the lamp when all 3 lights are blinking. If you can hear the arc from the ballast the lamp should light if the lamp is operational.A new lamp should solve your problem.
Mar 01, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP5067W Television Logo
137 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
