Question about Blade Saws
How to remove stanley circular saw blade guard
  • 16 Answers
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
  • 15 Answers
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
Posted on Nov 18, 2008
  • 195 Answers
SOURCE: My Bosch CS20 circular saw's blade guard is sticky
Take to a compressed air hose and blast away sawdust,if greasy spray with mineral spirits,let dry.
Please rate. Thank you. jj505
Posted on Mar 30, 2009
  • 141 Answers
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to and download a breakdown for this tool.
Posted on Feb 03, 2010
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
Dec 20, 2016 | Bosch Saws
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Oct 11, 2008 | Saws
Saws Logo
42 people viewed this question
Top Blade Saws Experts
Level 1 Expert
Are you a Blade Saw Expert? Answer questions, earn points and help others
