No flow condition for more than 2 hours error hydropool
My spa is showing an OHH message. What is causing this message?
Make and model would help. How about my best guess?
OHH means OverHeated Heater caused by an error
One of the Water Temp Sensors has detected 118°F (47.8°C) In the Heater and Spa Functions are Disabled. You Must Press Any Button to Reset when Water is below 108°F (42.2°C). Check for Water Level, Flow Restrictions, Closed Valves, Air Bubbles, and Pump Prime, or Continue for a Detailed Test Procedure.
WARNING:
A Heater Overheat Error Message may indicate Excessively High Heater Temperatures which can Scald or Burn!
If the Heater is Not Cool Enough to Safely Service, allow the Heater to Cool before Continuing Testing.
A Heater Overheat Condition that generates an "OHH" Error Message is Most Likely the result of a Low Flow Condition. Therefore, "OHH" is considered to be a Flow Related Error.
Check for All of the following Conditions:
1.Low Water Level.
2.Blocked Suction Fitting.
3.Blocked Skimmer.
4.Dirty Filter.
5.Too Many Closed Jets.
6.Closed Slice Valve.
7.Heat Related Pump Not Running.
8.Heat Related Pump Not Primed.
9.Contact your Dealer or Service Organization.
DO NOT remove the protective covers from any electrical enclosure, or attempt to service any related electrical device, unless you are a qualified electrician or service professional.
As a responsible adult, always check the topside control panel display for errors and verify safe water temperature before using a spa, and before allowing children to use a spa. Safety should ALWAYS be your first consideration
Nov 15, 2015 | Pool & Spa
Hydropool hot tub
see if voltage from transformer if ok board
Oct 07, 2017 | Pool & Spa
Hydropool hot tub
Check your filter. It may be clogged. This will restrict flow and prevent the pressure/flow switch from actuating. The heater will think that water is not flowing and not allow the burner to produce heat.
Jan 31, 2014 | Pool & Spa
F2 error code
An F2 error code means usually that you have a flow issue in your hot tub or you have a part malfunction. The best thing to do with an F2 error code is to go through a trouble shooting diagnosis. Start by cutting the power and letting the unit cool down and then do a reset of the equipment. If that does not fix your issue then do a water flow check, clean your filters, release air locks, remove debris from your intakes and returns. If your problem still remains look to replace or repair fuses, heater elements, or your circuit board. I hope this helps. http://www.thecoverguy.com/backyard-blast/f2-error-code-trouble-shooting/
Nov 09, 2013 | Great Lakes Spas Pool & Spa
Why does it backfire and quit after riding for 1 hour?
is it running out of gas? backfire is caused by a lean condition. I'd check the fuel path from the tank to the carb and clean the carbs. could have something floating around in there occasionally blocking fuel flow.
May 06, 2013 | Arctic Cat 2005 400 4x4 Automatic
Hydropool hot tub error code 5n will not start up
The 5N error code is actually an SN error code which means one of your sensors is bad.
Rod Kidman
www.uspartscenter.com
Dec 01, 2012 | Intex Automatic Salt Water System for ...
Flashing code 90 .
The 90 error code is caused by two conditions:
1) the unit is under heating the water (not hitting the set temperature)
2) the fan is encountering resistance to air flow, which causes it to over correct
The most common causes for this conditions are:
1) insufficient BTU supplied to the unit
2) clogged fan motor or vent
3) insufficient makeup air
4) improperly installed exhaust vent
Nov 10, 2009 | Noritz Tankless Water Heaters N-0931M
Error code HF
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F 2 error code
F2 usually means that there was an over temperature condition in the oven cavity. A stalled cooling fan could be a related condition. The usual causes are:
Welded relay contacts. In this case you'll need a new ERC
Cooling fan stalled or blocked air flow to rear of unit.
High resistance inoven sensor leads or connectors.
Dec 22, 2007 | GE JTP27 Electric Double Oven
Washing Machines Logo
456 people viewed this question
Top Washing Machines Experts
