Question about RCA Audio Players & Recorders
RCA RT2600 No sound, for a while the speakers would just hum and if you hit the top of it would start working, no have no sound coming out of speakers, but display looks fine.
Master_Tech
  • 770 Answers
SOURCE: Maytag Perfoma model PYE2300AYW
Bad start winding in motor
Posted on Jan 31, 2008
  • 9 Answers
SOURCE: rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Posted on Jun 27, 2008
  • 13 Answers
SOURCE: rca rt2600 when i press power botton i hear a click sound and doesn't turn on
you're having a startup problem, u should take to an expert.
Posted on Aug 29, 2008
  • 449 Answers
SOURCE: Hum & noise coming from the speakers
IF it was too load you probable blew the speaker Just disconnect the side that is making noise or is it both side?
Posted on Dec 17, 2008
  • 40 Answers
SOURCE: only humming sound from speakers, rca rt 2250
If its humming no matter what on all inputs, that means the internal electronics are worn out or damaged. This can be from a number of different things and isnt worth trying to have it fixed do the fact it would cost more than just buying a new one.
Posted on Jun 29, 2009
RCA RT2600 sound problems
You should first try unplugging it for 30 minutes and that should reset it and has fixed the problem on other ones before.
Also, do the speakers hum at all or is it dead silence?
Thank you for further comments to my question.
Have a Good Day.
Apr 20, 2008 | RCA RT2600 System
I am getting no sound from my speakers, but im getting video. i have all the outputs and inputs in the right places. what are some possible problems?
Operator error. Mis-set switch somewhere Use a medium or low volume level until you find it.
Have you followed the manual used the Test Tones to set it up? How did it sound at that time?
Have you and evaluated every indicator on the front to understand what they mean in the context of source selection?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2600-Home-Theater-Systems-manual/id/402ag606/t/2/
See page 23.
No audio.
Make sure the speakers are connected.
Check the input connections.
Check the power cord connections.
Make sure the MUTE signal on the front panel is off.
Make sure the digital setting (optical, coaxial or analog) is correct.
Check that the headphone is not inserted.
Mar 07, 2011 | RCA RT2600 System
Rca rt2600 no sound, if you switch on the power the display comes up and within a seconds it shows OVERLOAD in the display and it automatically turn off. all speakers had disconnected too. please help me...
One of the audio output amplifier ics are toast the faulty one will need to be desoldered from the board and replaced, they run at about $10 each normaly. The faulty one will generaly be quite burnt.
Aug 18, 2009 | RCA RT2600 System
I have a new Phillips 42" LCD and it only has a digital audio OUT on it, how do i hook it up to the RCA RT2600 with the digital audio...for some reason it is not wanting to give me any sound?!?!?!?!?
Be sure you have selected digital audio and enabled the digital audio out on the phillips tv audio setup menu, then be sure that the RCA rt2600 input mode is set correct
Mar 19, 2009 | RCA RT2600 System
No sound from speakers when tested for polarity
you must have a loose connection somewhere
even blown speakers make some sound
Feb 01, 2009 | RCA RT2600 System
RT2600 Issue
The DSP sttings control which speakers are working.
May 10, 2008 | RCA RT2600 System
No sound coming from speakers
check the speaker connections for any short circuit and also for polarity.
check if mute is highlighted on the screen
check if the audio output of the player is properly connected (optical / coax or RCA
this should solve your problem
If not tell me your connection configuration with regard to input output.
Regards David
Jan 31, 2008 | RCA RT2600 System
RCA RT2600 Speakers stopped working.
I bout mine used an it has absolutely no problems you probably got one that they knew wasnt really working in the first place.
Jan 25, 2008 | RCA RT2600 System
Rca rt2600 OVERLOAD PROBLEM
Jan 06, 2008 | RCA RT2600 System
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
