Question about Oreck Vacuums
How to raise the brush on an Oreck XL series?
  • 328 Answers
SOURCE: oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Posted on Dec 29, 2007
Agent Don
  • 310 Answers
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
Posted on Apr 09, 2008
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 4 Answers
SOURCE: how do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Posted on Apr 24, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Oct 30, 2016 | Oreck Vacuums
Hi do you carry the roller brush parts for this model?
Hi Rochelle,
This is Leland with Crucial Vacuum,
We carry the roller brush, and some other products for the Oreck XL, which you may find in the link below:
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for readers, use code: FIXYA10
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendlycustomercare representatives on the line ready to assist you.
Jan 29, 2016 | Oreck XL Power Team Upright Vacuum -...
How can you do a height adjustment on Oreck XL Series vacuum
Oreck makes two different attachments for putting on the bottom of your vacuum to raise it up. They have one for the older Classic styles and one for the newer XL models. This is the only way you can raise the brush on an Oreck.
Jul 18, 2012 | Oreck Vacuums
Oreck XL suddenly lost power
wiring in handle has loose connection or the brushes in the motor needs replacing. cost $18 for new ones.
Mar 08, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL9100 Brush clogged with hair
The pulley will turn off, then the end will pull off. Some of the replacement brush rolls, the pulley may be pressed on and may or may not come off with out ruining the end.
Apr 22, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
57 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
