Question about Mitsubishi Televison & Video
Mitsubishi LT-55265 led LCD tv has no sound, still beautiful picture. Had subwoofer and I removed it as thought it was problem, still no sound
Purchased in 2010 and love the picture quality. How do I get sound from tv speakers since I removed the Definitive Technology ProCinema 60 system that came with the tv.
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
  • 90 Answers
the problem is the audio amp board has been fried. It needs to be replaced. This will restore the actual sound transfer to and from the speakers.
Posted on Feb 08, 2009
SOURCE: cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
Posted on May 31, 2009
  • 3 Answers
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Posted on Oct 26, 2009
  • 447 Answers
SOURCE: Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Posted on Feb 03, 2010
Why is my replacement LED Power Supply Board not functioning properly?
Power supply board is not the culprit - check out your inverter board which is responsible for the back lighting.
Feb 03, 2016 | Samsung Televison & Video
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
My Lt-55265 LED Mitsubishi blue light is on & the green light constantly flash - HELP
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty or firmware is corrupted.
Jul 13, 2015 | Mitsubishi LT-55265 55 in. HDTV LCD TV
The subwoofer by DT ProCinema 600 doesn't work
I had the same problem when I wanted to swap my PCicon1.png 1000 for the PC 2000. The later interfered with my view on the tv. What I did was raise the tv on a couple of pieces of MDF. I painted the edges of the MDF to match the tv stand. Looks great - is very solid as far as support for the tv - and allowed me to get the PC 2000smile.gif
Nov 04, 2014 | Definitive Technology ProCinema 600 black
Very low sound
Check your sound setting under the TV menu. Most newer TVs only have two 10watt maybe a quality sound system!
Oct 13, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi 265 input problem
Type in the name for the device your connecting to the input---blue ray,cd,game
Jan 20, 2013 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Front speaker from my 600 isn't working
I just ran into this in 4 of my 5 DF Procimema 600 speakers. I ended up taking them all apart (be aware - this will probably void any warranty). To do this, you have to take the speaker grill off. Next, using a small phillips head screw driver, take out the top two screws on the front of the speaker. Note - everything you need to do will be from the front.. you don't actually remove anything from the top of the speaker. Next, using a pair of needle-nose plyers (or tweezers or whatever you have) remove the 6 little star-shaped plugs. These are where the spikes on the speaker grill insert to hold it in place. I thought they were some sort of weird screw at first until I removed one, then realized they are actually just a rubber plug. They pull right out - no twisting. Underneath them are 6 more phillips head screws - remove these and the front plate, speakers and all, will (should) pull right off without damage. The problem, well with all of my speakers at least, is that the connections inside come loose or fall off. I just took my needle-nose plyers and squeezed the connectors both where the wires run to the back of the case, and also to where they attach to the speaker. This literally solved all my problems and now my speakers work flawlessly again. Don't forget to put the white insulating material back in place before you put the speaker back together and you should be good to go. I hope this helps!
Jul 20, 2012 | Definitive Technology - Procinema 600 -...
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
I have a remote for tv manufactured 2010 . remote #bn59-01042a and want to use it to control surround sound jvc power unit how do i program it?
One Remote for Multiple Devices The way to control external devices with that remote is to use Anynet+. Check your owner's manual for it. It's listed as an application on the tv menu.
With Anynet+, just one remote control that works with up to a dozen devices, using HDMI cables to connect them to your HD TV. That means HDMI provides superior audio and video quality, neatly connected.
You can control a cable box, DVD or Blu-ray player, home theater system and more through the Anynet+ network-and that includes devices such as digital cameras and camcorders. One thing to remember-the devices must be Anynet+ enabled for the network to activate.
Exclusive Samsung Technology
The technology was introduced by Samsung in 2007, and has been upgraded since then. It's exclusive to Samsung products.
How Anynet+ Works It's a wired network system. By accessing a special menu on your Samsung TVs, you can control any connected device using nothing but the Anynet+ remote.
The remote adjusts volume and picture on any component. In fact, Anynet+ is so smart that the moment you insert a movie disc into a Blu-ray or DVD player, all AV equipment connected to your TV automatically turns on, including external speakers.
Another nice feature is that you don't need to have a component within your line of sight to make it work. In fact, you can have your whole Anynet+ system enclosed within a cabinet, and still be able to control it.
A Simple System
Anynet+ does all the work for you. Multiple devices are consolidated into one easy system-a central location for viewing home movies and pictures, too. There's no confusing networking or complicated wiring to set up. The touch of one button turns everything on or off, or puts everything into standby mode.
Apr 01, 2011 | Samsung LN32C530 32 in. TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
