Question about Sportcraft Exercise & Fitness
Need treadmill belt sportcraft 3-1-04-050 FH The treadmill works good but needs belt There is no instruction to replace it model# TX.ORC 04050
erpaalai
  • 999 Answers
SOURCE: turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Posted on Aug 11, 2009
Gackmaster
  • 12 Answers
SOURCE: i have a sportcraft tx 2.5 treadmill thats needs
Can you give more details? are you saying it stops 7 seconds after you step on it, (every time)?
If so, have you had the treadmill a while? this is an indicator of a worn belt. the belt is not sliding like it should, and drawing too much current. your control board will 'clip' the current off after a pre-set time, to avoid burning up components.
other things it could be:
1. your belt is too tight. did you tighten it lately? When did your treadmill start doing this?
2. The motor is going bad, and drawing too much current.
3. motor control board is bad.
look at your motor's current rating: measure the current draw when you get on it. if the current draw is ~ 80% of the rated current of the motor, and your belt is good,..and not too tight, it could be the motor.
if the treadmill is stopping while only drawing 4 or 5 amps, I would lean towards the control board is bad.
cheapest way to get started troubleshooting. Ensure the belt is not too tight, (adjust to only about 3 inches slack, when you pull up on it). next. buy some belt lubricant and lube it up.
If this doesn't fix your problem, keep looking for other fixya help. someone with SportCraft TX 2.5 specific experience. Sorry, I only have generic help here.
good luck.
Posted on Jan 27, 2010
  • 26 Answers
SOURCE: Where can I find a replacement sensor wheel for a
Try Icon Service Group. You can google them and find the web address. They are an excercise equipment warranty provider but will also see you parts.
Posted on Jun 16, 2010
  • 1212 Answers
SOURCE: location of speed sensor on sportcraft tx 400 treadmills
It is a simple magnet and Hall effect transistor if you have 2 small wires. It usually attaches to the 1/8 inch mini plug. You can test it with an analog meter, the resistance will be stable at rest, and with treadmill in motion, the resistance will change as the magnet passes the hall effect switch. moving the track at slow speed manually will be enough to see the needle move. Speed is calculated off of the rate of those pulses.
Posted on Jan 23, 2012
ercupa190
  • 12223 Answers
SOURCE: My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
Posted on May 07, 2012
Motor Control Board
go to www. fitnessrepairsparts.com and get it.
God bless you
Jun 11, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
A backwards E appears on my treadmill model 3-1-04-050 FH what does this mean?
Read your instruction manual, section troubleshooting for indication.
However you must adjut THE reed switch, see the diagram attached, clean, and tigh the connector wires very well. God bless you.
Run the software calibration for diagnose, and troubleshooting too.
Jun 07, 2012 | Sportcraft Tx 455 Sportscraft Treadmill...
Sport trac treadmill shuts off after a few seconds
1) LUBE the deck belt, this produce enough friction, by lack of LUBE
2) Lube the roller bearing, very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Dear sIR:
May 06, 2012 | Sportcraft TX 400 Walking Belt
Treadmii belt
Dear Sir:
Adjust according with the instruction manual, see the diagram attached.
if you do not have i. manual go for free download www. manualsonline.com or www. iconservice. com .
sincerely. God bless you.
Apr 21, 2012 | Sportcraft Tx 4.9 Model 4041 B Walking...
Turned on, runs a few seconds, shuts off with a #3 on display
Aug 06, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
