Question about Kenmore Washing Machines
Used Kenmore stackable model#00732790 Washer will not turn on nothing Dryer works. Was told washer started smoking Clattering the towels were wrung out It was plugged into an outlet not used
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 139 Answers
If the washer is smoking... DO NOT USE!!!! probably a motor/electrical fault. either carry out a repair or buy a new one.
Posted on Apr 23, 2017
Buffalo12980
  • 625 Answers
SOURCE: used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Posted on Sep 12, 2007
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
  • 84 Answers
SOURCE: Washer spins, but not as fast as it should. The
Check the drain pump and /or filter not jamming / blocked
Posted on Nov 09, 2009
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
graemevm
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
We have a stackable kenmore washer and dryer. The belt started to slip and smoke on a heavy wash load. I replace the belt but it still smokes and wont spin. Is there and adjustment?
Hi, There are no adjustments. Make sure the pulley on the idler and the drive pulley are tirning freely. It is possible the transmission is locked up and the belt will not turn properly.
If all the pulleys are free, start the washer in the spin cycle while watching the drive pulley to see if it turns.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
Oct 13, 2008 | Washing Machines
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Plug in for washer on a Kenmore stackable washer/dryer
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
