Question about Vizio Televison & Video
Used a shopjimmy video to check standby voltage on a Vizio D650i-B2. Its supposed to be 5 volts. My meter shows an oscillation from 1.3 to 3. Please advise...is the power supply out? Thanks
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: sony kdl-40s4100 no red standby light.When power
Does it make a click sound when powered on?
Posted on Nov 02, 2010
gopakumarg43
  • 75178 Answers
SOURCE: What is the AC voltage input range of the power supply board. I think it is 110-240 volts. Please advise. For immediate reference, please see the image of the power supply board by clicking http://as
110 > 240VAC is the input voltage. Auto select by the regulator board inside. Electro help
Posted on Mar 28, 2015
mileso
  • 3320 Answers
SOURCE: I need to change the resolution to 1080 on a vizio D650i-B2
The resolution for TV's is auto sensed by the content being sent to it.
If you are playing a 720p file, you cannot make it 1080p. 720p vs 1080p Can You Tell The Difference Between HDTV Resolutions
Posted on Apr 26, 2015
gopakumarg43
  • 75178 Answers
SOURCE: I have a vizio d650i b2 is not turn on have blinking power light 2 year start tirning off by it self ones in a while now nothing happen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 13, 2016
I have a vizio model # d650i-b2 the sound goes out on a regular basis. what can i do?
It is hard to say but most likely you need a new main board for that TV especially if the sound goes out after it warms up
Jan 24, 2018 | Vizio Televison & Video
Vizio D650i-B2 lost picture
with the green issue I would think main. t-conns bad too. are you sure its not cable box ? we have had many with green picture issue and sound loss
Dec 02, 2017 | Vizio Televison & Video
Vizio main board # 3655-0122-0150 7C
Board # 3655-0122-0150 is the main board not the PS board as mentioned in the previous message it can be purchased from shopjimmy but its not a cheap board...below is the URL for the board..How does the set behave? sound no picture, picture no sound, dead, has standby light, poor picture...ect
http://www.shopjimmy.com/vizio-3655-0122-0150-main-board-for-xvt553sv.htm
Nov 10, 2017 | Vizio Televison & Video
I have a vizio e65x c-2 , it shut off on me, and won't turn back on..... no lites @all. I would like to know how to test the power board to see if it needs replaced, or the logic board. Any help is...
First thing to do is see if the main fuse is blown, if it is then the power supply needs to be changed or the hot side of the board serviced. Use extreme caution if working on the hot side of the power supply board as there are DC voltages over 300 volts there...If the fuse is good check the 5 volt standby supply voltage, generally on Vizio its pin 1 but there will be a legend to tell what pin it is. if its around 5 volts its good, if not the power supply low side has issues, and sometimes this is bad capacitors. Next thing to check if you have 5 volts is the PS on terminal , find the correct pin get your meter on it and turn the set on, the 0 volts with the set off should go to about 3.5 volts, if it does then the main board is good and its a power supply issue, if you don't see about 3.5 volts then look at a bad main board, There is a fuse in the main board that can be tested but its rare its bad...Hope this helps some
Oct 16, 2017 | Vizio Televison & Video
I have a 65 inch Vizio. Model d650i-b2. It won't turn on, no startup lights, nothing. Just acts as if it's not even plugged in.. what could be my problem? Thanks
Probably you have a problem in the power supply board .
Vizio lcd or led always has a problem in the standby circuit of the power supply .
Jul 30, 2017 | Televison & Video
HOW TO IN STALL A TV BASE STAND ON A 65" MODEL NO:D650i-B2
https://support.vizio.com/s/article/ka61a000000DWK4AAO/D650i-B2-Model-Information?language=en_US
May 02, 2017 | Televison & Video
How do I remove the back cover on a Vizio D650I-B2
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Jul 24, 2016 | Vizio Televison & Video
How do i fix the colors from my tv they are all wrong
Please use your remote to access the video portion of the setup screen. You should find a reset video to factory defaults there or in the initial setup portion. Your manual should point you to the proper section to find these.
Dec 01, 2014 | Vizio Televison & Video
Will not turn on
It has a bad standby voltage circuitry on the power supply. This is very common since the standby section of the power supply is constantly on even when the TV is off. The standby voltage powers the circuitry in the TV so that when you use the remote or turn on the buttons it turns on. All TV has standby voltage that is constantly on. This standby voltage is 5 Volts DC. Usually a diode or some electronic components go bad. Explaining to you how to fix that is very technical and requires knowldege in electronics which is a broad and difficult subject to understand.
Jun 26, 2010 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
50 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
