Question about Grilling
How do I replace the grill burners on a Kirkland 720 0011Grill.
How do I access the bolt on the burner at the back? It looks like there is a nut and bolt on the back of the burner and the end is put into the knob area. It does not look like you can access without taking the sides and back off and I missing something?
  • 1462 Answers
SOURCE: Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Posted on Apr 06, 2007
SOURCE: gas grill loses pressure while side burner does not
I had the exact same problem with my Jenn-Aire and so I replaced the regulator for $20 and it now works fine.
Posted on Feb 28, 2009
SOURCE: all 3 Burmers won't stay lit
I contacted the company. Phone number 800-694-0013. You can order replacement parts thru them but they cannot take credit cards by phone you have to mail in the payment and they will Fed-Ex the part when they receive it. The lady I spoke with was very nice and helpful, she stated these grills are made for Meijer's pretty much exclusively and they are made in China and that if you can locate their website it is all in Chinese. She also stated the distributor has opted not to sell the replacement parts for these in the store.
Posted on May 29, 2009
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
SOURCE: Ducane F7011013 FireLight II grill I am looking
I have a brand new Ducane Firelight II Camp Stove/Grill in need of a regulator/hose assembly. Would you be interested is selling me the parts from your stove? kpirish810@yahoo.com
Posted on Sep 06, 2009
How to change burner on kirkland 720 gas grill
You should not need any special tools. The burners are usually held in place with screws If you take the top grills off, there may be a set of covers or shrouds over the burner unit. They usually just lift out. After you have removed those covers, study the burner unit and locate the screws, which are uasusally in the front.Lift the front of the burner and the back of the burner should come out with a little twist.
May 31, 2014 | Costco Kirkland Grilling
BBQ grillware
Try Calgary bbq center they are on line part could be called burner carrier !
Feb 20, 2012 | Grilling
Got an ss215pi as a gift cannot get drip tray out the left nut that holds the burner on sticks down to far-- about 2mm ?
You would have to remove the bolt first and then access the drip pan. If you need a replacement drip pan please visit www.ibuygrillparts.com
Dec 29, 2010 | Napoleon Gas Grill
Looking for replacement parts for SPG90B Campcheif Big Gas 3
I looked around online and could not find anything for my gas grill. My burners all disentergrated. I found Walmart is a good source for cheap generic grill parts but only at certain times of the year. I recently replaced 3 burners on my gas grill. The new burners were build like a trombone so one size fits any grill. The metal looks a lot better than the original equipment. At $10 a burner I am back in action!
Sep 29, 2010 | Camp Chef Big Gass III - SPG-90B Grill
How do I install replacement burners for my Charmglow 720-0036-hd-05 grill
Replacing Burners on Charmglow 720-0036-HD-05.
1. Disconnect the gas line to the "side burner".
2. Remove the two "side shelves", each of which is held on by 4 large phillips screws.
3. Remove the "control panel" that is held on by two smaller phillips screws at each side of the "control panel".
4. Remove the "front baffle" located directly behind the "control panel that is held on by 4 phillips screws.
5. Lift off the "cooking grills" and the "flame tamers" (the plates over the burners) so that you can see the burners.
6. Now you can slide each of the burners forward and then left them out of the grill.
Replace everything in the reverse order.
Apr 07, 2010 | Grilling
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
How do i go about replacing the middle burner on my Ducane bbq, model number 30400046? I have already ordered the part.
Remove the cooking grate so you will have unrestricted access, remove the flame tamer (it should be able to come up without effort) to expose the burner. At the back of the grill there is a screw that attaches the back part of the burner to the grill. Remove the screw, then grip the burner and pull it towards the back of the grill, this should release it from the gas valve in the front. To put the new burner in, just do all these steps in reverse...let me know if this works for you, if not I can walk you through it via chat.
Sep 24, 2009 | Ducane 30400040 Stainless Steel Grill
TECH II CERAMIC BURNER PROBLEM
just removed ceramic burners on my patio II-had to grind heads off of stainless stee bolts[ 4 on each burner],bolts do not have nuts instead they have theaded collers which have deteriorated and turn when i turned the bolt.used a 4" angle grinder-remove gas cylinder before attempting this!
Apr 11, 2009 | Tec Patio II Grill
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Mar 21, 2009 | Weber Genesis Silver B Grill
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
