No picture on recorder but have sound. Picture & sound on tv
SOURCE: umsuccessful instalation of tv capture card, sitapatir@gmail.com
first the sound driver is not installed in ur pc
no picture would be shown unless u have not installed ur sound card
Remove the card & clean it & placed it & proerly installed the graphic card driver it might solve ur all 3 problem
Posted on Dec 04, 2008
  • 55 Answers
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Posted on Jan 16, 2009
SOURCE: no picture when I play back on vcr
it took me several days, but I've finally figured out what my problem was. I could record while my tv was on, but as soon as I turned it off, there was no picture but there was sound.
I had to disconnect my HDMI connection. Instead use the component connection from your HD cable box to your TV. You will still have a HD picture, and you will be able to record with the TV off.
Posted on Feb 23, 2009
  • 8457 Answers
SOURCE: vcr will not record sound any more.
The RCA cable audio wire might not work.
Make sure the RCA cable in right connection.
Tries a new RCA cable one.
Posted on Aug 13, 2009
  • 3 Answers
SOURCE: sound and picture jumping
This is probably because this camera records in HD format which will jump around when played on computers that are not very high performance. You need at least 2gb of RAM and a decent processor.
Otherwise, the codec is missing or old for playing the format.
Posted on Nov 19, 2009
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
No picture when I play back on vcr
Are you using AV connections(Red, Yellow, White) cable connections? If so The video connection may have come loose.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
Can I record sound only through Camera sound inputs from Record
You might need a source picture from a camera or off the tv so that the DVD has some sync pulses to actually record the sound. Some won't do anything without any pictures.
Jan 30, 2009 | Philips DVDR70 DVD Recorder
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Samsung DVD-VR 375 records but sometimes I get only sound
Some program have copy protection or your installations cable and setup try to set lower resolutions and make sure you see the picture on TV before record
Or tell me how are your installation from which device to where
I may able to help you
Cheers
Dec 09, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Umsuccessful instalation of tv capture card, sitapatir@gmail.com
Dec 04, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
