Question about Coffee Makers & Espresso Machines
I need a new gasget (plastic seal) for the top of my espresso machine "Maxim Expres-2 Model EX-202.
My machine pours steam out from the pressure valve, the machine gets very very hot ( to hot ) cant even touch the steam arm
For repairing your steam valve you must take it out from boiler(2 screws m6 hold valve to boiler) before unscrew valve you must take of valve plastic knob and steam pipe.
Carefully you take off the seal of valve, seal prevents axle from completely unscrewing. You unscrew the axle and you go to turner (metal parts shaping machine) there you repair the top of axle, it is like pencil, you only need to sharpen it a bit, than you change 2 o rings in axle, put it in back. Instead the seal you use now one fitting !/4" and you screw it on to prevent getting out the axle
Feb 09, 2011 | Gaggia Classic Espresso Machine
Water leaks out from the water container
I would suspect the seal on the machine where the tank sets on the machine. There is a plastic cap that looks like a doughnut, that will pry off (there are 2 hooks, 1 on each side). The seal is under neath. If you can stick your finger in the center of the seal and lift it out it needs to be replaced. When you put the new one in, run your finger nail around the outside edge of the seal to get it to slip in or you could damage the new seal.
Oct 29, 2010 | Saeco Royal Digital Plus Coffee...
My Gaggia Syncrony Compact has developed some sort of leak. Every few days I notice a pool of water spreading across the countertop in our pantry and pooled under the machine. The leak might be happening...
HI
Oct 24, 2010 | Gaggia Syncrony Compact Coffee...
I have a Salton/Maxim Ex-450A which needs a new carafe. Are any available?
My rice cooker #RA7A has a brplen lid, need lid top also. Where can I get a replacement part#20138W PN #20652W. and what would be the price.
Jul 17, 2009 | Salton Coffee Makers & Espresso Machines
I need an instuction booklet for my salton model ex 96 esspresso machine
Go to:
http://www.coffeecrew.com/learning/185-the-salton-maxim-ex96-manual-for-everyone
Jun 04, 2009 | Coffee Makers & Espresso Machines
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
