Stopcode: driver currupted expool. Computer will not start. can hear fan running. How do I get it to come on.
Drive not recognized driver missing or currupt
a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 30, 2010 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
I have a Beyond Micro 500 GB External HDD. When we plug it into the computer and doesn't respond to the computer. We hear the fan in the drive but it doesn't appear on computer? Can you help? Whats...
Hi!,
The sound you hear is the sound of the disc which is running anyway it may be a driver issue please uninstall the driver then restart the PC and reinstall the driver and check the issue.
Aug 27, 2010 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
I start my computer but its only a blank page
some files have been currupted on yur hdd n u nedd 2 recover it
Jun 18, 2009 | Apple MacBook Pro Notebook
How do i do a master reset on my laptop and fix a currupt C drive
Run system restore disk or run it from the bios or the hard drive.
Apr 22, 2009 | Computers & Internet
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
Windows xp home edition is currupt
You can try a few things...
1. Uninstall any suspect programs ... Go into Control Panel, Add Remove programs and remove them.
2. Buy and install good anti-virus software ... this will remove threats.
3. Create a new account with Administrator rights and delete all old accounts.
4. Download Spybot Search and Destroy and Adaware. Run the scans on these programs they will remove alot of spyware.
5. Run System Restore, (from Start, Programs, Accessories, System Tools) Restore your computer as far back as you can....
and ... keep your laptop away from pesky teenagers!!!!!
Jan 06, 2009 | Compaq Presario C700T Notebook
Computer boot up
This looks like a problem with you video card drivers. I had this problem last week! ;o) The screen turned off while in the Windows logo.
You need to boot in safe mode and reinstall the drivers of your video card.
TO BOOT IN SAFE MODE :
Boot your computer and tap F8 every seconds. If you get to a blue "boott selection screen", press ESC, and restart pressing F8 every second. You will get to a black windows selection menu with the arrows. Select the boot in safe mode option and press enter.
ONCE IN SAFE MODE:
In XP, once in safe mode, you PC will boot with minimal settings and default drivers. Go to START, CONTROL PANNEL, SYSTEM, HARDWARE, DEVICE MANAGER. You should see your display adapters in there. If one has a yellow exclamation mark, then you need to re-install the drivers.
TO REINSTALL THE DRIVERS:
You need to find the graphic card CD you had when you purshaed it, or download the drivers on the internet. Go to a friends house, and download them on your manufacterer's website (ie : ASUS, ATI, etc.). You need to know your card's model name for that. It should be in the Device Manager, where you looked earlier (Ex: ASUS MAGIC 128MB)
Once you reinstall the drivers, you should be ok.
Worked for me. It makes sense because the screen turns off when it tries to load the currupted drivers.
I hope it helps.
Dec 31, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
