Question about LG Refrigerators
Lg lrsc26925tt replaced freezer fan motor put it back together now I have no freezer light no ice and no water
melnavz
  • 1226 Answers
SOURCE: Ge Ice Maker Gs25sgmcbs
Hello!
There is a problem in the water dispenser outlet of the freezer, in this case i will suggest call service tech of the freezer and the ice maker so that the system will be personally diagnosed thoroughly to resolved the existing problems.
Service center in your area maybe available and not then the vendor is the right person to contact.
best reagards, melnavz
Posted on Mar 04, 2008
abhishek33
  • 1239 Answers
SOURCE: After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Posted on Oct 10, 2008
BIKER T
  • 909 Answers
SOURCE: Ice maker wont shut off
So many different types. lots of info needed. In short, lg have DIPswitches on main board. By adjustment of these switches, the water in can be controlled.I dont think there is a water sensor on these makers per say.Does the water ever switch off at any time and if so, is the inflow time constant?. Assuming the solonoid valve is not defective.
Posted on Jan 30, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Posted on Jan 05, 2010
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
We have an error code on the water dispenser screen - Er IF What is the fix for this problem? This is an LG French door model LFX25950SB.
You have a ice fan motor problem. This fan motor is what feeds cold air to the icemaker. Try unplugging the refrigerator for a few minutes to reset the computer. Plug it back in and see if the error code stays off. If it returns, you will need to remove the ice fan motor from the freezer and see if ice has built up and blocked the air flow. The ice fan motor is located behind the back wall inside the freezer. You will have to remove the drawers and slide supports to remove the back wall. There are 2 fans behind the wall. The one on the left is the ice fan motor. Good luck.
Jun 22, 2011 | LG French Door Refrigerator with External...
I have an lg lfd2286osb and the front panel says er ff. i hear the fan running for a short time and then it turns off. Is there something i can do to fix this.
Your fan is iced over needs to be cleaned out. Take everything out of the freezer including the drawers and remove the back panel. You will find the fan motor in the upper section full of ice. Melt all the ice out of it and replace everything back together. Pull the plug to reset the computer and everything will return to normal.
BE CARE NOT TO DAMAGE REFRIGERANT LINES.
Good luck
Jun 16, 2011 | LG LFD22860 Stainless Steel Bottom Freezer...
Model# LRSC26925TT freezer and fridge wont get cold enough to maintan food for more than a day or two. freezer doesn't make ice either anymore.
sounds like the fan motor in the freezer is not working is it running ? if not turn off frig.let it defrost manually, open doors. find the motor. see if you can turn it.. if it turns. restart frig .see if it starts. if not. new fan motor is needed.good luck
Aug 21, 2010 | LG Refrigerators
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice cube maker not working. digital display not
The ice fan is frozen. It is located behind the rear panel inside the freezer2.gif drawer. I had the same problem with an LG refrigerator in November 2008 that was fixed under warranty. (There is a Kenmore model that is made by LG.) They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Oct 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker don't make ice and display code error
The ice fan is frozen. It is located behind the rear panel inside the freezer drawer. I had the same problem in November 2008 that was fixed under warranty. They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Sep 07, 2009 | LG LFX25960ST Stainless Steel French Door...
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Refrigerator LG LFC25760ST Serial # 701KRUC00022 PROBLEM ERROR CODE: ER FF What is this? How can I solve the problem?
Hi, The FF error code indicates that the freezer fan motor is defective. You could also get this code if ice is preventing the fan from turning. Please set up service for refrigerator before the fan motor gets worse !
It's written like this in the repair manual:
Which means what I just wrote above about the fan motor!!
Error detection category:
Abnormality of BLDC FAN Motor for Mechanic Room
Error Display: FF
Error generation factors:
It is caused when F/B signal isn’t over 115 seconds during BLDC FAN motor operating
Remarks:
Poor BLDC Motor connection, DRIVE IC, and TR.You can check the below trick, if that might work on your model :-
Pull the top and bottom baskets out, and take the back panel out from inside. There would be asolid block of ice built up around both fans and wires. Take a blow dryer and gradually melt the ice around the fans and wires. Then, pull the remaining ice chunks off of the wires. Then put the thing back together and it should clear the message.
Unless call a tech from LG.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Jul 08, 2009 | LG Refrigerators
Refrigerators Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
